Turn signal, plate light, and taillight connectors - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 4 (permalink) Old 07-11-2013, 06:42 PM Thread Starter
Question Turn signal, plate light, and taillight connectors
So this winter I will be tearing the bike down to make more modifications. One of them will be run/turn/brake LED strips, being as picky as I am I do not want to cut and splice. I want to find OEM connectors and make my own harness/plugs for a simple plug and play and easy return to stock if needed. I believe that these are the signal connectors:
I am not sure what model/style the plate light or tail light connectors are. I tried taking picktures but aparently my phone did not actualy take the picture, I will post pics of the connectors on the bike in the w/in the next couple days. I appreciate any and all input. Thanks
rferrara is offline
post #2 of 4 (permalink) Old 07-12-2013, 09:38 AM
Seawolf_il's Avatar
a brand that makes almost all of these types of connectors is Molex:
http://www.molex.com/molex/products/...annel=PRODUCTS
I'm sure you will find what you are looking for in there.
Seawolf_il is offline
post #3 of 4 (permalink) Old 07-13-2013, 03:29 PM
twowheeladdict's Avatar
There are OEM connectors under a rubber cover at the back of the rear fender. That is where I connected in my SkeneDesigns run/turn/brake LEDs.
twowheeladdict is offline
post #4 of 4 (permalink) Old 07-15-2013, 09:56 PM Thread Starter
i was trying to figure out exactly what they are so that I order the right ones so that when I do connect LED's i do not need to splice them in. there are so many options that are similar I didn't know if someone had already done the same thing and may be able to eliminate the trial and error ordering process. I do appreciate though.
rferrara is offline
Removing the back taillight metal plate teddyfigo Vulcan 650 S 20 12-02-2016 11:12 PM
Replacing Right Front turn signal and Left Rear turn signal qxinfinity Vulcan 750 0 11-03-2010 04:02 PM
License Plate/ Taillight relocater Clip4487 Vulcan 900 12 08-25-2010 08:59 PM
Turn Signal/ License Plate Relocator kit Vulcan 900 Custom scotchman Vulcan 900 19 04-25-2010 03:11 PM
Stock License Plate/Turn Signal Bracket Black_Vulcan003 Vulcan 900 3 10-02-2009 03:09 AM
