Advice for PC autotune install? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 7 (permalink) Old 07-03-2013, 10:18 PM Thread Starter
RainDragon's Avatar
I am planning out the PC autotune install on my 2012 Voyager. I am wondering where is the best place to put the O2 bung? A picture would be great. Any other advice from those with a successful install?
2012 Vulcan Voyager 1700
ISO grips // RacnRay throttle mod
Thunder teardrop air kit // decorative left side plate // throttle body gasket
V&H Twin Slash slip-ons // DynoJet PCV w/ ignition + E80's map (modified)
Kuryakyn Longhorn Offset Dually ISO-pegs // Mirror extensions
Marvellas rear passenger foot pegs // grab rails
RAM cup holder // GPS holder // Phone holder // Camera mount
Drift Stealth 2 // Sena SMH10 Bluetooth headset/intercom
Russell Day Long seat w/ backrest
RainDragon is offline
post #2 of 7 (permalink) Old 07-03-2013, 10:52 PM
Combat72's Avatar
Here is where I put mine. Also put it at an angle per their recommendation.
Frank
Name:	O2 Sensor Bung.jpg
ID:	36641   Click image for larger version
Name:	O2 Sensor Placement.jpg
ID:	36649   Click image for larger version
Name:	O2 Sensor Placement2.jpg
2010 Voyager/ Metallic Diablo Black/Metallic Imperial Red
1972 Norton Commando - Yellow
PCV(Fuel & Ignition) With Autotune
Gear Advance Fuel & Ignition Mapping
Cobra 4' Scalloped Tip Slip-Ons
Wrapped Exhaust Manifold
Kuryakyn ISO Grips with RacnRay Mod
Kuryakyn Bar End weights
Ultimate Mid-Rider
Polk Audio DB521 speakers
K&N Air Filter
Rear Speakers
Mirror Risers
iPod Adapter
Combat72 is offline
post #3 of 7 (permalink) Old 07-03-2013, 11:03 PM Thread Starter
RainDragon's Avatar
Frank
That's perfect, Frank, thanks for the pics.
post #4 of 7 (permalink) Old 07-07-2013, 06:58 AM
bikesrfun's Avatar
Frank
Mine's in the same spot.
Vietnam Vet
2011 Fast Black Vaquero
'03 Mean Streak, gone
but not forgotten
bikesrfun is offline
post #5 of 7 (permalink) Old 07-07-2013, 08:31 PM
Combat72's Avatar
RainDraggon,
I have been running gear dependent mapping as well. I have a fuel table and ignition table for each gear. I tried different maps and ended up starting with a zero map and let the autotune adjust accordingly after several rides. The reason I decided to do that was to lean out the A/F ratio in 5th and 6th gear in the cruising range (5% to 20% throttle position) in hopes of increasing the gas mileage. The autotune will make trim adjustments for each gear table and you can decide to accept them or not.
Frank
Ultimate Mid-Rider
K&N Air Filter
Rear Speakers
Mirror Risers
iPod Adapter
Combat72 is offline
post #6 of 7 (permalink) Old 07-07-2013, 10:55 PM Thread Starter
RainDragon's Avatar
RainDraggon,
Frank
Aside from the obvious fun of figuring out how to do it, is the gear dependent mapping working out for you? Were you able to achieve any better fuel economy in cruise?
post #7 of 7 (permalink) Old 07-08-2013, 07:23 AM
Combat72's Avatar
I had some decel popping issues that I had to resolve. Just getting back to playing with the fuel savings mapping. I leaned the map out just a little as Power Commander recommends not to go over 14.7 to 1. Not close to that yet. Rode this weekend and got to 180 miles and the fuel light hasn't come on yet.
Frank
Ultimate Mid-Rider
K&N Air Filter
Rear Speakers
Mirror Risers
iPod Adapter
Combat72 is offline
PCV Autotune Install bikesrfun Vulcan 1700 4 01-08-2012 11:38 PM
PCV Autotune Module RJH Vulcan 1700 1 05-11-2011 10:43 PM
Must Read! - PCV and the autotune Klemm05 Vulcan 2000 0 03-26-2011 11:43 AM
Caution With Pcv(5) Autotune Bytehead Vulcan 900 0 03-31-2010 02:03 AM
