Rubbing noise from belt area - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 6 (permalink) Old 06-26-2013, 06:38 PM Thread Starter
new kawi rider's Avatar
What does the belt sound like when its to tight. I have rubbing noise at low speeds. Like coming up to a stop and pull the clutch in and i can feel it rub. Its kinda rub then fine then rub as the tires turn. Had tire changed on vacation and it started doing it then. Just had a new commander II put on today and its still doing it. Never did this before the last 2 rear tire changes. Its driving me nuts help !
2010 Voyager
Scootworks 2 inch fat risers
vance&Hines slipons
Mustang Wide Touring studded
PCV
Michelin commander 2
Ipod adapter
Titanium header wrap
8 to 12.5 inch bagger windshield
Iso grips with Rays throttle mod
Chrome rear floor board covers
Kams Kit
new kawi rider is offline
post #2 of 6 (permalink) Old 06-26-2013, 10:30 PM
diehard rider's Avatar
On my 900 it almost sounded like a gear grinding, I just changed my rear tire so I went back and loosen the tension on the belt and relined it and the problem quit. Good luck!
2012 GREEN/BLACK VAQUERO
Kawi Quick release backrest
Kawi Passanger floorboards
Kawi Luggage rack
Klockwerks 9" windshield
Mustang Seat
Mustang pass backrest pad
Ipod adapter kit/Ipod
Black ISO Grip
Offset ISO highway pegs
PC5 W/ignition
Freedom Performance True Dual Exhaust
Altrimax HP 195/55/16 car tire.
Leather saddlebag chaps
Thunder mfg Tornado air intake
Thunder mfg Throttle Body Gasket
diehard rider is offline
post #3 of 6 (permalink) Old 06-26-2013, 10:40 PM
Sounds like the belt to me. They can track like that. Loosen up the belt a little and make sure it is tracking properly. Also remember these belts have a memory of sorts they can get stretched and will not track true after that. If you can not get it to track get a new one.
maxtech1 is offline
post #4 of 6 (permalink) Old 06-27-2013, 12:30 AM Thread Starter
Thanks guys. The belt never made any noise the first 15000 miles. Must of been adjusted wrong on the last tore change.
2010 Voyager
vance&Hines slipons
PCV
Ipod adapter
Kams Kit
post #5 of 6 (permalink) Old 06-27-2013, 05:47 AM
A too tight belt will make a loud whining sound. I had brought my 2010 Nomad in to my dealer for a belt check up, and they adjusted it, and afterwards the whining sound aroud 45 mph was terrible. It took those idiots three tries to get it right. I knew it was too tight, and I should have done it myself.
I recently had the Commander II's installed by a local mechanic and he got the belt right the first time. So, it is not your tires.
I will never go back to my dealer for anything, ever.
Take care, Eric
ridgeman06 is offline
post #6 of 6 (permalink) Old 06-27-2013, 07:58 AM
Old Bear's Avatar
Year/Make/Model: 2017 Kawasaki Vaquero
Color: Red
The bracket on my belt guard had been bent, letting the belt rub a hole completely through the guard! Take it back to the guy that changed the tire and let him check to see if he bent the bracket. It doesn't appear to take much for that to happen.
Jerry "Old Bear" Barker
Clarksville, TN
Americas Guardians PS MC
Tennessee 16-A Chapter
"Blaze" 2017 Vaquero
Old Bear is offline
Squeak or tire rubbing noise in rear wsomers Vulcan 1500 4 07-27-2014 09:19 PM
Grinding noise coming from front Belt pulley area linuxsurfer Vulcan 900 30 02-12-2014 06:22 AM
Swinging arm bearings going, belt rubbing? Neil Newnham Vulcan 1700 19 12-15-2012 08:44 PM
VN800A - Loud Rubbing Noise from Front Wheel fcastle_2000 Vulcan 800 6 08-23-2010 04:18 PM
Rubbing noise from front end. Mark2K Vulcan 2000 1 08-09-2010 07:41 PM
