PCV With Auto Tune Question - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 6 (permalink) Old 06-24-2013, 09:58 PM Thread Starter
Combat72's Avatar
I have been running a PCV (fuel & ignition) with Auto Tune. I tried different maps but decided to start with a 0 map and let the Auto Tune make adjustments. I accepted the trims a couple of times and the bike has been running good. I have not been accepting any trims recently and it seems to be down a little on power based on the butt dyno. In looking at the trim adjustments the auto tune is taking away fuel in the cruise range (5-20% throttle). How does the auto tune work if you don't accept/clear the trim adjustments? If you ride, don't clear the trim tables then ride again how is it adjusting?
Frank
2010 Voyager/ Metallic Diablo Black/Metallic Imperial Red
1972 Norton Commando - Yellow
PCV(Fuel & Ignition) With Autotune
Gear Advance Fuel & Ignition Mapping
Cobra 4' Scalloped Tip Slip-Ons
Wrapped Exhaust Manifold
Kuryakyn ISO Grips with RacnRay Mod
Kuryakyn Bar End weights
Ultimate Mid-Rider
Polk Audio DB521 speakers
K&N Air Filter
Rear Speakers
Mirror Risers
iPod Adapter
Combat72 is offline
post #2 of 6 (permalink) Old 06-25-2013, 01:01 AM
davidsheek's Avatar
I don't know about that, but I do know if you start out with a "O" map and take away from that you'll be super lean. That's why you're down on power.
I would advise not to go below zero.
davidsheek is offline
post #3 of 6 (permalink) Old 06-25-2013, 08:59 AM Thread Starter
Combat72's Avatar
David,
The first 2 trims I accepted added fuel. I dropped my adjustment percentage down to 5%. I have not accepted any trims since then. I loaded a copy of the map after I accepted the 2nd trim adjustment and I can tell it has more power. I'm just curious why the power is decreasing if I'm not accepting the trim adjustments where fuel is being taken away.
Frank
Ultimate Mid-Rider
K&N Air Filter
Rear Speakers
Mirror Risers
iPod Adapter
Combat72 is offline
post #4 of 6 (permalink) Old 06-25-2013, 09:34 AM
davidsheek's Avatar
Oh, guess I misunderstood before.
Guess if it were me I would pull up the actual map that's in the unit to see if anything has changed. A decrease in power means not enough fuel when trying to adjust fuel.
Did you ever get my map to try out? I've sent it to so many guys that I don't remember.
post #5 of 6 (permalink) Old 06-25-2013, 11:52 AM Thread Starter
Combat72's Avatar
David,
You did send me your map. I'm using your ignition advance on my current map. I've noticed in the past with maps that if I don't accept trim adjustments and don't clear the trim tables the performance gradually decreases. Could it be decel braking and exhaust reversion causing it make bad adjustments?
Frank
Ultimate Mid-Rider
K&N Air Filter
Rear Speakers
Mirror Risers
iPod Adapter
Combat72 is offline
post #6 of 6 (permalink) Old 06-25-2013, 02:40 PM
davidsheek's Avatar
Originally Posted by Combat72 View Post
David,
Frank
That sounds logical to me. But I hope Ray sees this and shines the light on this subject. Keep us posted okay.
PCV Auto Tune Dual Probe - Observations Wadegster Vulcan 1700 10 08-16-2014 10:55 PM
PCV Auto Tune Wadegster Vulcan 1700 0 04-29-2014 08:25 AM
To those running Auto Tune wbilotta Vulcan 1700 0 06-09-2012 07:42 PM
Auto Tune Install HELP ShadaarLogath Vulcan 900 2 01-27-2012 10:30 AM
Auto tune molo Vulcan 900 7 06-07-2010 10:20 AM
