2012 Vaquero " Cure POPPING " ??? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 6 (permalink) Old 06-22-2013, 09:47 AM Thread Starter
I just purchased a 2012 Vaquero - 3000 miles - with V & H Slipons & Air System ( brand?). I get a lot of back firing when I let off on the throttle. Will a Cobra Powrpro FI2000 or something else correct this ??? Thank you for your help !!!!
Blue Moon is offline
post #2 of 6 (permalink) Old 06-22-2013, 10:36 AM
Old Bear's Avatar
Year/Make/Model: 2017 Kawasaki Vaquero
Color: Red
Yup, do a search on here, you will find tons of info - and somewhat of a raging debate between the FI2000 and the Power Commander V. I've still been debating myself!
The FI2000 Power Pro (watch those model numbers!) continuously adjusts based upon monitoring injector information, but retains no information on shutting down. It takes it a couple of blocks worth of driving for it to rebuild its information for maximum performance. Advantage: you can change whatever (pipes, fuel, whatever), whenever, and it will adjust to it.
The PCV requires a map that matches your bike, and you can tweak the map to your heart's content! Ideally, you will get a map from a tuner that knows what the heck they are doing with the bike on a dyno! A bad map will make the bike run like crap. Oh, the PCV with ignition is the preferred model.
Both can cure the afterfiring that you are hearing. While plug-in tuners with maps are nothing new, the debate comes from if a product can provide a very similar gain by only monitoring the FI pulse. Personally, I read of too many users that are thrilled with the Cobra units to discount its effectiveness. I think it comes down to a matter of if you want plug-n-ride or you like to tinker! Oh, I am no expert, just an old grunt trying to figure this thing out myself! YMMV!
Jerry "Old Bear" Barker
Clarksville, TN
Americas Guardians PS MC
Tennessee 16-A Chapter
"Blaze" 2017 Vaquero
Old Bear is offline
post #3 of 6 (permalink) Old 06-22-2013, 11:41 PM
Set your idle adjustment through the LCD screen adjustment to +100 rpm and go for a test drive.Its proably been turned down so it sounds better at idle.The problem with that is not enough air gets into the combustion chamber to complete the fuel burn before it enters the exhaust-hense a popping or bang in exhaust system.You should be able to back off the idle adjustment once you prove to yourself that was the issue.I run mine at 0 postion now and only have the odd pop or bang.If I run a +50 no issue at all,but the idle at an intersection does sound a little high.This is a do it yourself possiable cure.A proper dyno tune should cure the issue also.
ta-kid is offline
post #4 of 6 (permalink) Old 06-23-2013, 05:06 AM Thread Starter
Thank you for your help !!!! Bob
post #5 of 6 (permalink) Old 06-23-2013, 05:07 AM Thread Starter
Thank you for your help !! Bob
post #6 of 6 (permalink) Old 06-23-2013, 05:08 AM Thread Starter
Thank you for your help !!! Bob
Decel popping with new V&H exhaust - 2012 VN 900 Classic autofs General Vulcan Talk 18 09-12-2013 12:02 PM
1700 Nomad excessive "popping" BLACKJACK New Member Introductions 1 07-23-2013 03:18 PM
Oil to cure transmission whine? stevejack Vulcan 1700 21 06-16-2011 09:31 PM
Anyone have a cure for the high idle after start up warm on 09? BSE(illinois) Vulcan 900 31 04-13-2011 03:02 AM
Possible ways to 'cure' lean fuel mixture? Lost Californian Vulcan 900 11 09-04-2010 04:38 AM
