Why are my rear shocks leaking oil (1700Vulcan Classic LT - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 8 (permalink) Old 06-21-2013, 01:10 PM Thread Starter
Angry Why are my rear shocks leaking oil (1700Vulcan Classic LT
The other day I noticed there was a pool of oil under my left rear shock absorber. My bide seems to ride normal and push down on the rear of the bike to move the shocks, they seem to work okay. Is the shock shot? Can I fix it? What is the best remedy - replace? New OEM's are around $500 and would prefer not to go that route. Thanks for any help you can give
CatfishHunter is offline
post #2 of 8 (permalink) Old 06-21-2013, 01:42 PM
davidsheek's Avatar
Well the damping effect will stop after enough oil leaks out. I'm sure they are sealed and unrepairable, but not positive.
The best remedy would be to buy a set of after market shocks. This is assuming you warranty is expired.
davidsheek is offline
post #3 of 8 (permalink) Old 06-21-2013, 02:19 PM Thread Starter
Thank you for your help. I'm not really that mechanically inclined, and thought the shocks were just air dampened. Guess not.
post #4 of 8 (permalink) Old 06-21-2013, 04:05 PM
twowheeladdict's Avatar
The question you asked is why. Have you added air to your shocks? did you use a zero loss hand pump?
Did you hit a large pothole?
If your bike is still under warranty, it might be covered if the mileage is low.
I like progressive 412 non-air shocks for replacement shocks. Used them on my 1200 Voyager and they improved the ride and handling.
twowheeladdict is offline
post #5 of 8 (permalink) Old 08-09-2013, 10:37 AM
had oil on my left shock at the bottom turned out to be a manifold gasket leak and the wind was pushing it on my shock
smblackmon is offline
post #6 of 8 (permalink) Old 08-09-2013, 05:29 PM
Aussie.Nomad's Avatar
Year/Make/Model: 2010 Vulcan Nomad
Color: Black & silver
They say that the shocks are unrepairable, but you can.
Here in Oz, shock repairers drill a hole & use a grub screw with a rubber insert & inject the oil in with a syringe. They also can reseal them.
I have had 3 done this way on my Roadstar
Aussie.Nomad is offline
post #7 of 8 (permalink) Old 08-10-2013, 09:04 AM
barryge's Avatar
I took apart one of my shocks to see if there was a way to shorten it. They do come apart just need a press of some sort to compress to get the spring clip off. There are a couple of o-rings in them and one may have a nick in it. If it not leaking that much just take out the valve core and with a syringe inject some power steering fluid in it.
barryge is offline
post #8 of 8 (permalink) Old 09-09-2013, 11:59 PM
Kaz71's Avatar
It is noted in owners manual that if you add air to them to adjust the ride you so desire to NOT use a compressor airline or you could possibly blow the seals. Not sure if that is what you did, but I know it is not to exceed a certain amount of psi when adding air, and use a hand pump.
2011 VN1700 Classic.
Cobra Speedsters
Cobra Fi2000 PowrPro Tune
K&N Air Filter
Mustang Sport Touring Seat - Studded
Slipstreamer Stealth Windshield
Kawasaki Engine Cover Trim
Sissy Bar Studded Backrest & Luggage Rack
Kuryakyn ISO Deluxe Brake Pedal Pad
Kuryakyn Flamed Floorboard Cover
Kuryakyn Adjustable Cruise Peg
Kuryakyn ISO Large Male Mount Pegs
6,000K Xenon HID Kit
Carroll Leather Saddlebags
Wolo Bad Boy horn
Kaz71 is offline
1996 1500L C3 leaking front head leaking oil vscoy00 Vulcan 1500 0 05-29-2015 08:32 AM
Oil leaking under my tappet covers larwillrider327 New Member Introductions 1 10-06-2014 08:24 AM
Cheapest NOMAD in Phoenix >>>$3995<<<< louichie Bikes For Sale 1 12-08-2011 04:14 PM
Rear jug buring oil. Found oil leaking through reed valve in valve cover. Pa. Vulcan Vulcan 800 0 06-03-2011 11:16 AM
