update positive neutral - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 16 (permalink) Old 06-13-2013, 04:06 PM Thread Starter
I posted a while back about my vulcan transmission being kinda clunky when shifting and the positive neutral switch not working all the time. The bike sat at the dealer for over 2 weeks before he even looked at it. I was sweating it was a big problem on my almost new bike. He said no problems, that's just how they work, $100 please. Glad to get it back but hey .....2 weeks before a road test?? Poor service turnaround imo.
oldncrzy is offline
post #2 of 16 (permalink) Old 06-13-2013, 05:36 PM
Bubba in TX's Avatar
I've never had a problem hitting neutral so far.... 10k miles... My Voyager isn't called Betty Clunker for nothing......
The only time mine doesn't clunk in a gear change is from a start and I am in 6th by the time I am doing 15 miles an hour.... other than that.... clunks every gear change...
Bubba in TX
2011 Voyager "Betty Clunker"
Some people collect T-shirts
I actually ride
Voyager 1700 owners...
WRAP your pipes....
You will be glad you did...
U.S.A.F. Retired
Nye County Nevada
Motor Officer Retired
Blue Knights Texas 43
Bubba in TX is offline
post #3 of 16 (permalink) Old 06-13-2013, 06:10 PM
Yes they clunk into gear and sound like a java grinder when riding down the road but 10k with only oil and tier change and when you go out to ride no surprises just get on and go what could be better. My gear indecator dose lag or hang in 5th and od
nomad11 is offline
post #4 of 16 (permalink) Old 06-13-2013, 08:45 PM
They kept your bike two weeks, and had the gull to charge you 100 bucks for a road test. Probably road it five minutes and found it normal. I am a auto tech and we would never charge that much for no problem. In fact we would say no charge. Just come back for service when needed. That wins a customer for life. I would never go back there.
jp58 is offline
post #5 of 16 (permalink) Old 06-14-2013, 05:39 AM
twowheeladdict's Avatar
$100 for a test ride? WOW! I guess that will keep you from wasting their time, which means when there is something potentially serious you will be hestitant to tell them.
If you positive neutral finder will let you shift into second while at a standstill then there is either something wrong with your positive neutral finder or Kawasaki redesigned it.
If it were me, I would call Kawasaki directly and ask them how the positive neutral finder works.
twowheeladdict is offline
post #6 of 16 (permalink) Old 06-14-2013, 08:52 AM
davemc's Avatar
I recall reading that the positive neutral finder will not work if the bike is not on level ground.
2009 Vulcan Voyager, Wolo Bad Boy air horn, Kuryakyn ISO grips with contoured throttle boss, Kuryakyn Adjustable Floorboard Cruise Peg mounts with pegs, Cobra Tri-Oval exhaust, K&N air filter, temperature dipstick, saddlebag rails, Superbright trunk light flasher.
davemc is offline
post #7 of 16 (permalink) Old 06-14-2013, 10:32 AM
king_arthur1953's Avatar
I have not ever had a problem with the neutral finder as long as I am stopped.
Pastor Ron
"A man's true character is determined by what he does when no one is looking."
Pastor "That Biker Church"
President North Arkansas HonorBound Motorcycle Ministries
President/Founder "Wounded Spirit Ministries Inc."
Patriot Guard Rider
USAF 1971-19752010 Voyager 1700 ABS
Kawasaki CB Radio, J&B Elite headset, Ray's Throttle Mod, Road Commander II, Sagebrush Whale Tail Tank Bib, Firestik NGP CB antenna, Firestick AM/FM antenna eliminator, Amsoil engine oil and coolant
king_arthur1953 is offline
post #8 of 16 (permalink) Old 06-14-2013, 11:00 AM
hamster
Guest
Posts: n/a
hi
the neutral finder only works properly if the motorcycle is. when it rolls just a little. then it can happen that it does not work or is difficult to find.
it is best to connect them in the first transition and then in the idle.
sometimes looks after the engine oil. kawasaki writes 5 liter motor oil.
with 5.3 liter motor oil on the gearbox quieter and better.
sorry for my bad english
greeting hamster
post #9 of 16 (permalink) Old 06-14-2013, 10:42 PM
BOTM Winner, April 2013
tstorey823's Avatar
My experience indicates the positive neutral finder works perfect IF: 1. The bike is NOT rolling. 2. You are in 1st gear shifting UP.
If you are in 2nd shifting down, it will NOT stop in neutral.
AKA The Green Hornet
tstorey823 is offline
post #10 of 16 (permalink) Old 06-18-2013, 12:39 AM
hank43's Avatar
Positive Neutral finder?? What's that? I'm lucky if I can find ANY gear. Forget about the indicator in the instrument cluster, half the time it doesn't show any gear. Oh Yeah, and it does clunk.....
hank
2009 VV1700 ABS, Champion triked
hank43 is offline
Bad Positive Neutral Finder? _Kodiak_ Vulcan 1500 12 07-26-2018 06:08 PM
positive neutral finder oldncrzy Vulcan 1700 9 05-14-2013 07:06 AM
Beach crusier UK update of THE UPDATE lammytez Vulcan 1500 12 07-17-2011 12:27 PM
Trouble with positive nuetral finder Darknight Vulcan 900 12 04-23-2010 08:41 AM
Switch oil and troubles with positive neutral finder. baxter Vulcan 1700 10 09-03-2009 09:31 PM
