front wheel removal - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 4 (permalink) Old 06-11-2013, 04:38 AM Thread Starter
front wheel removal
Am I missing something....to remove the front wheel (excluding brake calipers), all that is needed is to undo the pinch bolts on the RHS and then unscrew the axle with the 22mm hex key ?
either this thing is stuck good or I've missed some thing..
any help ?
Ozburner is offline
post #2 of 4 (permalink) Old 06-11-2013, 06:41 AM
RogerE's Avatar
any help ?
According to my service manual:
If your bike is ABS equipped you need to remove the front wheel rotation sensor and sensor bracket bolt.
Then remove the front brake calipers on both sides.
Then loosen the axle clamp bolts and the front axle.
Then jack up the bike in the front and remove the axle and take off the front wheel.
NOTE: The manual does not indicate if the threads are right hand or left hand for the axle, and I am not sure. That could be the issue.....
Patriot Guard Rider
Taps Bugler - Bugles Across America
Sons of the American Legion
I spent most of my money on wine, women and motorcycles. The rest I wasted.
RogerE is offline
post #3 of 4 (permalink) Old 06-12-2013, 01:55 PM Thread Starter
Hmmm..not that this would stop the axel from moving...but yes ABS sensor...thanks...
Ozburner
Ozburner is offline
post #4 of 4 (permalink) Old 09-08-2013, 08:37 PM
Can anyone give the torque specs for tire removal, front and rear..? i.e. brake calipers, pinch bolts, ABS sensor bracket, and axle? This is for the Vaquero. thanks
BTW, bought an AC Delco digital torque wrench and it works great. (actually, it's not really a wrench, it's an digital attachment you put on your ratchet.
Bitsa is offline
Front wheel removal Traumahawk Vulcan 900 3 05-22-2012 11:25 AM
help front wheel removal tommyj Wrench Heads 10 03-22-2012 07:11 PM
Rear wheel removal Im Back Wheels and Tires 1 09-03-2010 05:38 PM
Rear wheel removal on 2006 Vulcan Classic Little Eddy Vulcan 1500 2 07-25-2010 09:50 PM
Rear Wheel Removal - Leave Fender On? IMSnake Vulcan 1600 4 03-25-2010 09:32 PM
