1700 Classic LT PCV Map - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 5 (permalink) Old 05-28-2013, 06:42 PM Thread Starter
Hi there,
Does anyone have any ideas on where to get a map for a 2009 170 classic LT that has vance and hines big shots with a stock air filter? I downloaded the 17-006-004 map from the power commander website. The bike does not run very well with this map, has a hesitation when you roll on the throttle in any gear and occasionally pops/back fires through the exhaust? Any suggestions? Thanks.
izdbye is offline
post #2 of 5 (permalink) Old 05-28-2013, 09:08 PM
Curt1968's Avatar
1700 classic
I have a 1700 classic with big shot pipes and stock air filter. Without changing anything else, it runs great. Very little de-cel pop. I actually just added the K&N filter and believe it or not, it now has even less de-cel pop and it was pretty little to begin with. I have not added fuel management system. The service manager told me with the combo I was running , nothing else would needed. Not sure if that helps you or not.
Curt
[SIGPIC][/SIGPIC]
2012 1700 Classic
Curt1968 is offline
post #3 of 5 (permalink) Old 05-28-2013, 09:21 PM Thread Starter
Thanks, I will load the zero map tomorrow and take it for a run. The zero map, should effectively, return it to a stock set up.
izdbye is offline
post #4 of 5 (permalink) Old 06-08-2013, 08:34 PM Thread Starter
Curt1968, are your pipes turning blue at the crossover? If so, It may be running way too lean with the stock ECU mapping. I took my bike into a shop to attempt fine tuning the PCV to get rid of the hesitation as you roll on the throttle. Nothing the guy did would get rid of the hesitation. I also had it run up on the dyno with the stock ecu mapping, vance and hines big shots as a test. It got scary lean (around 19:1 air/fuel) in the 2300-3100RPM range. I've decided to go back to the stock pipes.....I've thrown about $1500 into this already and the bleeding must stop.
izdbye is offline
post #5 of 5 (permalink) Old 06-08-2013, 11:08 PM
Curt1968's Avatar
I would say the crossover pipe is less blue and more brownish. I used chrome polish is clean it up. I have had little to no problems with the Vanes & Hines big shot pipes and the K&N filter. Runs great and I'm still getting about 40 MPG. Slight popping on de-cel but, very minimal.
[SIGPIC][/SIGPIC]
2012 1700 Classic
Curt1968 is offline
Vulcan 1700 PCV map badvulcan New Member Introductions 2 03-12-2015 02:13 PM
PowerCommander V for 1700 with PCV Map Switch dpbaker Bike Parts, exhausts, etc. For Sale 0 05-23-2013 07:51 AM
PCV map? cobra 2 into 1 w/ big sucker? redking Vulcan 900 12 05-06-2012 01:26 PM
VN900 Debaffle + Hypercharger.. PCV Map? Switch420 Vulcan 900 8 02-27-2011 08:19 PM
Help--- PCV - HK Strippers - Hypercharger = Which map? dutchinc Vulcan 900 3 04-24-2010 08:24 AM
