55 watt driving dights - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 4 (permalink) Old 05-25-2013, 08:25 PM Thread Starter
IL Vaquero's Avatar
I have serched and cant find the anser I need I have a 2011 vaquero it has a 80/100w headlampbulb in it and recently had the driving lights installed. I was wanting to put 55watt bulbs in the driving lights lot of deer where I live. Will this cause a problem with amps or should I go back to a 55/65watt headlamp bulb to keep from harming my chargeing system. thanks for any help.
Only a motorcycle rider knows why a dog sticks he head out the car window. Enjoy life.
IL Vaquero is offline
post #2 of 4 (permalink) Old 05-25-2013, 09:56 PM
twowheeladdict's Avatar
I think the OEM bulbs are 35 watt. So you want to go from drawing 11.25 amps to drawing 17.5 amps. I doubt it would be a problem with the alternator unless you are running heated seat and heated gear at the same time. I would make sure the wiring and fixtures are rated to handle the extra draw.
twowheeladdict is offline
post #3 of 4 (permalink) Old 05-25-2013, 10:11 PM Thread Starter
IL Vaquero's Avatar
Thanks Twowheeladdict helps alot.
post #4 of 4 (permalink) Old 05-27-2013, 02:12 PM Thread Starter
IL Vaquero's Avatar
Well put them in and blow no fuses with the bright light on did not have a chance to go for a ride because of weather let it warm up and no problem with heat so far.
Super Bright LED 2 inch 10 watt LED auxiliary light Rhyno General Vulcan Talk 3 06-22-2013 07:01 PM
H3 12V 25 Watt bulbs Old Syko General Vulcan Talk 0 10-23-2012 01:49 PM
Were can I get the 260 ohm 1/2 watt resister j6320 New Member Introductions 4 09-20-2012 09:08 AM
Just installed Shark 250 Watt Stereo Toymaker Vulcan 900 94 07-22-2011 09:46 PM
100 watt flamethrower? Skidaddle General Vulcan Talk 8 11-21-2009 02:49 PM
