Vaquero 1700, Sticky Clutch? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 7 (permalink) Old 05-08-2013, 07:32 AM Thread Starter
Just wondering if this is a sign I should be doing some particular maintenance.
I hadn't fired up the Vaquero 1700 since Friday because I just got the 1600 out of the shop, rode that around for a bit. This morning I decided to jump back on the Vaquero. It's parked in the garage, in first gear. Pull in the clutch, back it up...feels like I'm going up a bit of an incline. Odd. Clutch is all the way in.
Fire up the bike - lurches forward a bit. Hmm. Clutch is definitely all the way in.
Put the bike in neutral. Fire it up. Put it in first. Clutch is in. It's under power. Not much, mind you...I can resist it but it's definitely rolling forward under power a bit.
Play around with it a bit. Problem goes away. Ride it 15 miles to work without an issue.
Maybe it just missed me?
Lunatic is offline
post #2 of 7 (permalink) Old 05-08-2013, 07:33 AM Thread Starter
I should mention, it's a 2011 Vaquero, just shy of 24,000 miles.
Lunatic is offline
post #3 of 7 (permalink) Old 05-08-2013, 07:37 AM
Old Bear's Avatar
Year/Make/Model: 2017 Kawasaki Vaquero
Color: Red
WAG, air in the line? Just like brakes, after you pump it a few times, the air is pocketed and you now have a firm clutch. I haven't had the need yet to look for where to bleed air out of the system, so I can't help with specifics.
Jerry "Old Bear" Barker
Clarksville, TN
Americas Guardians PS MC
Tennessee 16-A Chapter
"Blaze" 2017 Vaquero
Old Bear is offline
post #4 of 7 (permalink) Old 05-08-2013, 08:55 AM
RACNRAY's Avatar
I highly recommend flushing and bleeding ALL hydraulic systems at least once a year. Heat, age and humidity are the biggest factors in hydraulic fluid deterioration and due to the fluid in the clutch system getting hot far more than the fluid in the braking systems that clutch fluid will deteriorate quicker.
RACNRAY
"TRUE HAPPINESS IS IN THE HEART,NOT IN THE OUTSIDE FIXES!!"
WITH OVER 42 YEARS AS A MOTORCYCLE TECHNICIAN/HI-PO SHOP OWNER I AM A PURVEYOR OF FACT NOT FICTION!
"WE LIVE OUR LIVES IN CHAINS NEVER KNOWING WE HAD THE KEY"
RACNRAY is offline
post #5 of 7 (permalink) Old 05-08-2013, 09:06 AM Thread Starter
Thanks Ray. I'll definitely have that done this weekend.
Lunatic is offline
post #6 of 7 (permalink) Old 05-08-2013, 02:21 PM
bigblockyeti's Avatar
Year/Make/Model: 2008 V2KLT
I have no experience with the 1700 specifically but have experienced this on a few other bikes I've owned. The clearance between the clutch plates and friction plates is very small even when the clutch is fully disengaged, usually only a few thousandth of an inch divided by all the gaps between every plate. As cold oil rests in these gaps it can provide traction from the friction plates to the drive plates to a greater degree than hot oil, (of which there is very little due to the centrifugal force when everything is spinning) this additional viscosity due to the colder oil could be the issue IF you know the hydraulic system is perfectly bleed. My own experience is usually that once the engine is started the clutch stops dragging, the only exception being with extreme cold or an oil with a viscosity much higher than is recommended. Hope this helps.
bigblockyeti is offline
post #7 of 7 (permalink) Old 05-08-2013, 05:40 PM
twowheeladdict's Avatar
Never happened on my Voyager, but has happened on my mean streak and some of my cable actuated clutch bikes. I try not to leave them in gear in my garage and don't have that happen when keep them in neutral.
twowheeladdict is offline
Sticky clutch and rapid takeoffs stevesmitty79 Vulcan 500 11 10-08-2017 07:45 PM
Sticky Clutch? Poncho Villa Vulcan 2000 5 12-19-2014 05:38 AM
1600 Sticky Clutch RockyNJ New Member Introductions 5 03-20-2014 07:32 AM
1600 Sticky Clutch RockyNJ Engine Work 1 03-20-2014 06:34 AM
sticky/stuck clutch kmac1 Vulcan 1700 4 12-08-2012 02:14 PM
