Tri-oval Baffle removal - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 15 (permalink) Old 05-06-2013, 04:09 PM Thread Starter
Has anyone tried to remove the baffle from the tri-ovals? I rode to Houston last week and the noise at 80 mph was not tolerable without earplugs. I would like to try to tone them down a bit with some stove rope or pipe wrap. When I looked at the end of the pipe I found four hex head bolts, but when removed, the baffle did not want to budge. I didn't break out the hammer yet but thought I would post the question here to see if anyone else had taken them out or tried to quiet them down, just a bit.
Most of my riding is below 70, and the tri-oval noise level is tolerable at that speed. But when I go on I-45 South to Houston, if I'm not going 80 I feel like I am going to get run over.
2012 Vulcan Voyager ABS
stoutman is offline
post #2 of 15 (permalink) Old 05-07-2013, 11:32 AM
RACNRAY's Avatar
The end cap on the Tri-Ova;s are an EXTREMELY TIGHT FIT and are difficult to remove.
There are actually 2 baffles in the Tri-Ovals. The first baffle protrudes into the body I believe about 6-10 inches on the inlet side. The end of that tube is capped and the exhaust flow must flow out of this tube thru openings in the side of that tube. That exhaust flow must then flow thru openings in the side of the long baffle tube that ends at the rear of the body.
Since exhaust flow goes from outside of the long baffle tube to the inside you must be careful in how you wrap the core as it will restrict exhaust flow and possibly reduce performance.
Loosely wrapping the long baffle tube would be a starting point. Analize the change in the sound, the power and mpg.
But yea those end caps are tuff to remove. Some penetrating lube and a slide hammer will do the trick.
HOPE THIS HELPS
RACNRAY
"TRUE HAPPINESS IS IN THE HEART,NOT IN THE OUTSIDE FIXES!!"
WITH OVER 42 YEARS AS A MOTORCYCLE TECHNICIAN/HI-PO SHOP OWNER I AM A PURVEYOR OF FACT NOT FICTION!
"WE LIVE OUR LIVES IN CHAINS NEVER KNOWING WE HAD THE KEY"
RACNRAY is offline
post #3 of 15 (permalink) Old 05-07-2013, 02:05 PM Thread Starter
Thanks for the reply Ray. Always good information in your posts. I think I'll try a heat gun on the end cap and an ice wrap on the pipe tube and try to get a little thermal expansion/contraction to help me out. If that doesn't work I'll see if I can find my slide hammer and figure out where to attach it to the baffle. I'll post the results.
stoutman is offline
post #4 of 15 (permalink) Old 09-09-2013, 04:41 PM
I am also trying to get the baffles out. End caps are off but the baffles won't budge. You have any luck?
2012 Voyager
crazy is offline
post #5 of 15 (permalink) Old 09-09-2013, 08:31 PM
rusty360's Avatar
I thought these were semi quiet unless you got on it? Was thinking of getting these but if it was that loud I may have to stay stock.
2014 Honda Gold Wing
2011 Vaquero sold
2009 900lt sold
rusty360 is offline
post #6 of 15 (permalink) Old 09-09-2013, 08:45 PM
Old Bear's Avatar
Year/Make/Model: 2017 Kawasaki Vaquero
Color: Red
Seems to be a personal preference thing. Running down the Interstate at 80 mph is getting on it a bit. I run around 80 mph on my commute to work, I find the sound soothing. I've been a little curious what kind of helmet the riders are wearing that do not like the sound. I wear a Shoei Neotec modular, and noticed that it does subdue road noise. Other thoughts?
Jerry "Old Bear" Barker
Clarksville, TN
Americas Guardians PS MC
Tennessee 16-A Chapter
"Blaze" 2017 Vaquero
Old Bear is offline
post #7 of 15 (permalink) Old 09-09-2013, 09:03 PM
I love the sound of my Tri-Ovals and I wear a Scorpion EXO-100 half helmet. It is the guy behind me that has complained about the noise at over 3000 rpm. Just my thoughts. I don't find them too loud on the highway and neither does my wife while ridding on the highway.
2010 Red Vulcan Voyager
Independent Amsoil Dealer
Snowcatnut is offline
post #8 of 15 (permalink) Old 09-10-2013, 02:16 AM
jase64's Avatar
I find that the tri ovals are very quiet , on the highway there real smooth..at 80 in 6th gear theres a low pitch rumble ..i love them.
jase64 is offline
post #9 of 15 (permalink) Old 09-11-2013, 04:23 AM
Rusty, you might also consider the Vance & Hines twin slash slip-ons. They sound great, though for me personally I wish they were a tad louder. But for you, that may be perfect.
You can check them out here, including a video clip:
http://www.vanceandhines.com/store/m...kawasaki/18371
3P
threepea is offline
post #10 of 15 (permalink) Old 09-11-2013, 07:43 PM
sandcrawler's Avatar
My OCD kicks in when I look at the V&H literature. They advertise as being under $450 and the price is actually about $470 and then the Kawasaki install instructions end along lines of "Now that you've installed those brand spanking new pipes on your HARLEY-DAVIDSON motorcycle...."
With that said, had I the money lying around I'd buy a set
Kevin W
STL Missouri
sandcrawler is offline
Problem installing the Cobra Tri-Oval Slip-ons kj052030 Vulcan 1700 18 09-29-2013 02:01 PM
Cobra tri oval slip ons justinmccurdy25 Vulcan 1700 3 05-19-2011 03:56 PM
Cobra Tri Oval 1700 Nomad rmorry Vulcan 1700 5 04-28-2011 02:13 PM
Cobra Tri-Oval Question! Vulcan09 Vulcan 1700 6 04-08-2011 02:16 AM
Cobra Tri-Oval Slip Ons Lobo Vulcan 1700 3 10-07-2010 08:11 PM
