Need help with PCV with AutoTune - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 6 (permalink) Old 04-26-2013, 08:50 AM Thread Starter
Angry Need help with PCV with AutoTune
I had a PVC with AutoTune installed on my 2012 Voyager with Cobra slip-ons
they started with map #M17-006-002 but i'm still getting back firing , they have re-mapped it a number of times but i still have back-firing, it was installed with a local authorized dealer in MA so i assume they know what there doing , anyone have a better map i could give them ? thanks in advance .
[email protected]
ajmills is offline
post #2 of 6 (permalink) Old 04-26-2013, 09:58 AM
AJ,
I think a better PCV map to start with would be the 17-006-006. That is for V&H slipons, but they should be closer than stock pipes.
You can also block off the fresh air hose to your PAIR system by plugging the hole in the upper left hand corner of your air box. (do a search on marbling the 1700.)
As for downloading another members maps; you shouldn't need to with the Auto-tune.
I don't have the Auto-tune but if I understand how it works then this should help.
Change to the -006 map and then ride the bike for a while. Accept the changes suggested by the Auto-tune and repeat.
Hope this helps.
2016 Indian Roadmaster
Thunder Black
post #3 of 6 (permalink) Old 04-26-2013, 11:04 AM
bikesrfun's Avatar
[email protected]
Get in touch with davidsheek as he has a good map for Cobra slip ons. Here is a thread related to this: https://www.vulcanforums.com/forums/s...ad.php?t=14889
Vietnam Vet
2011 Fast Black Vaquero
'03 Mean Streak, gone
but not forgotten
bikesrfun is offline
post #4 of 6 (permalink) Old 04-26-2013, 12:44 PM
RACNRAY's Avatar
BEFORE ANY FUEL INJECTION TUNING can be performed, either by auto-tune or on a dyno with a sniffer, as has been said, the fresh air hose for the PAIR system MUST be blocked off. Accurate fuel injection tuning is impossiblee to achieve with that system in operation.
Many Vulcan 1700's have intake system vacuum leaks between the throttle body and the intake manifold. Installing the gasket from Thunder Mfg. is a very good thing to do.
RACNRAY
"TRUE HAPPINESS IS IN THE HEART,NOT IN THE OUTSIDE FIXES!!"
WITH OVER 42 YEARS AS A MOTORCYCLE TECHNICIAN/HI-PO SHOP OWNER I AM A PURVEYOR OF FACT NOT FICTION!
"WE LIVE OUR LIVES IN CHAINS NEVER KNOWING WE HAD THE KEY"
RACNRAY is offline
post #5 of 6 (permalink) Old 04-29-2013, 12:29 PM Thread Starter
Hey Scott dumb question , what did you use to plug that plug that hole .
ajmills is offline
post #6 of 6 (permalink) Old 04-29-2013, 12:46 PM
I used an actual cork; like from a test tube.
Others have luck using a marble.
I think they push it into the hose put a tie wrap behind it then re-install the hose back onto the air-box.
I know there is a better write up on the forum under 'marbling'.
Thunder Black
Vaquero with PCV & Autotune Old Bear Vulcan 1700 16 09-01-2013 04:43 PM
PCV Autotune Install bikesrfun Vulcan 1700 4 01-08-2012 11:38 PM
PCV Autotune Module RJH Vulcan 1700 1 05-11-2011 10:43 PM
Must Read! - PCV and the autotune Klemm05 Vulcan 2000 0 03-26-2011 11:43 AM
Caution With Pcv(5) Autotune Bytehead Vulcan 900 0 03-31-2010 02:03 AM
