Tank Slapper - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
  • 1 Post By KawMan
post #1 of 6 (permalink) Old 08-12-2019, 03:45 PM Thread Starter
Tank Slapper
So last week, was on a trip and driving down an isolated road, took my hands off handle bars (which i occasionally do) to tighten gloves. Handle bars started to wobble. Most times it did not do this.
I had to replace the tires, so this week i Put Commander II on. What a difference in cornering and overall smoothness, but now if i lightly take my hands off bars at any speed, starts to wobble???
I have Counteract balancing beads in. As i did before.
ANy thoughts?
Shawn Graham is offline
post #2 of 6 (permalink) Old 08-12-2019, 05:20 PM
bearslayer's Avatar
Year/Make/Model: 2004 Nomad , 1985 BMW K100 X2 , 1985 Intruder, 1998 Ducati Monster, 1972 CL350, 1948 Indian CZ125, 2
Displacement/CC's: 125 -1500
Color: Blue & Silver , Black , Gray , Maroon,black,
With new tires and balance addressed unless the air pressure is too low I would look at properly torquing the steering stem. I believe on my Nomad it was 14 foot pounds for 1500 and 43 inch pounds for a 1600. this was using the reconfigured 36mm socket,
Steering Stem Nut Adjustment
That which does not kill me tends to really piss me off.
bearslayer is offline
post #3 of 6 (permalink) Old 08-13-2019, 06:21 PM
steering wobble
I've been running the commanders for a few seasons, Had hands -free wobble.
Replaced steering head bearing with All Balls roller type. Not quite gone.
Added Garry's fork brace.
Run front at 28 psi. rear at 42 psi
Hands free now.
bearslayer likes this.
KawMan is offline
post #4 of 6 (permalink) Old 08-13-2019, 06:24 PM Thread Starter
Replaced steering head bearing with All Balls rollewhar type. Not quite gone.
Hands free now.
What was your front psi when still a bit of wobble? I've read most people don't have such a low psi in front, even though that is what manual states. I put 34 psi.
Was it your steering head bearing or perhaps your steering head nut was not tight enough prior?
post #5 of 6 (permalink) Old 08-13-2019, 06:29 PM
bearslayer's Avatar
Cool
Hands free now.
Oh yeah I knew I did something else. I LOVE my fork brace, though it was a devil to get on. On my second set of Commanders , I run 34 in front. At 28 PSI she wants to turn in a little hard and tries to cup. Same as you n the rear at 42 PSI. Ride Safe
post #6 of 6 (permalink) Old 08-13-2019, 06:51 PM
I don't recall the original bridgestone tires having a wobble. That be the first 8,000 kms or so.
Never checked OEM head bearing torque. Just went straight to the rollers.
Wrecked the head nut using a flat end chisel to remove/tighten.
Bought a 43-45 mm bicycle wrench, cut in half to use with fairing in place.
Think part of issue was roller bearings not fully seated. The bicycle wrench worked real good with a new nut.
Have replaced fork springs with stiffer Racetech, max preload too. Maybe a touch too much.
That's a big tire up front, so not surprised Kawasaki has a low fill pressure. Just thought to go back to stock pressure and see how it goes.
Do mostly two up riding with full camping gear, so close to GVWR.
Front is good now. it's sweeper dips that brings wobble lurking...
KawMan is offline
