2012 Nomad noise from drive or motor? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 2 (permalink) Old 05-22-2019, 02:40 PM Thread Starter
Unhappy 2012 Nomad noise from drive or motor?
HELP ANYBODY! I got a 2012 Nomad with 9000 miles. When you are at a steady speed like 45 to 48 mph I start getting a weird ( scraping sound ..like metal rubbing metal) sound. If you give it more gas it goes away and you can hit a steady cruise speed of around 55 and it returns, same at 65...I've had it in 2 shops with no luck finding or fixing my problem. If you put a small amout of pressure on the clutch while keeping the gas on, its goes away and returns as soon as you release the clutch>>>>. anyone fought the battle before? Thanks
Nomad12 is offline
post #2 of 2 (permalink) Old 05-24-2019, 12:35 PM
Does it do it in neutral? And does it do it when stationary? Maybe it's not an engine problem but a drive problem.
Sent from my SM-N950U using Tapatalk
ksgjlg is offline
My 2012 Nomad..it is kinda sorta done...ish Dewey405 Vulcan 1700 10 08-18-2012 09:05 PM
2012 Nomad: need handlebar, footpeg, and backrest options Nerdybiker Vulcan 1700 2 08-04-2012 01:07 PM
2002 Nomad... high frequency noise vermontrider Vulcan 1500 8 11-20-2009 11:59 AM
Final Drive Noise - Considering a Swap BG528 Vulcan 1500 0 08-09-2009 08:45 PM
nomad clutch noise dblbucket General Vulcan Talk 0 08-05-2009 07:01 PM
