Starting to get concerned - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
  • 1 Post By Sabre-t
post #1 of 6 (permalink) Old 05-22-2019, 12:43 PM Thread Starter
I have just about 100,000 miles on my ride (160,000km) and other that oil, filter, and tires, I have not had to touch anything on it. Pulls strong, no oil burning, starts stops, etc. I am about to head out on a longer trip in a few months and wonder if I should have anything done to it. Might have a noise in the lower front end (cam chin tension?)
Any thought /advice is appreciated
Kevin
2009 voyager
kmac1 is offline
post #2 of 6 (permalink) Old 05-24-2019, 12:38 PM
Well I'm a new 2009 voyager owner and I was waiting for all the things to keep an eye on. I am selling my Nomad that has 90k and still runs phenomenally well. Maybe they corrected all of them on the voyager
Sent from my SM-N950U using Tapatalk
ksgjlg is offline
post #3 of 6 (permalink) Old 05-24-2019, 01:22 PM
Sabre-t's Avatar
Color: Red/Black
if that is all you have done on a bike that old and w/ that many miles, there are a LOT of things you should be looking at. checking, greasing, and torquing the steering stem bearings (i would recommend replacing them w/ all balls bearings). changing coolant, hoses, and related rubber parts. servicing brakes (pads, if needed, rebuild calipers - new rings & seals, new brake & clutch hoses). there is plenty more. you should get a service manual and get caught up on routine and periodic checks and maintenance.
having an unforeseeable major failure on the road is bad enough (been there, 2200 miles from home), but a failure that could have been prevented w/ proper maintenance...
VulcanRide likes this.
Installed:
Longer Kickstand
Dobeck EJK 3.0
Lucky Mirror Extenders
Wiring for Trailer
Ray's Throttle Mod
Things to do:
LET'S RIDE
Sabre-t is offline
post #4 of 6 (permalink) Old 05-24-2019, 01:35 PM
bigblockyeti's Avatar
Year/Make/Model: 2008 V2KLT
Rebuilding calipers?? I can see new pads but rebuilding calipers as a precaution ranks right up there with new piston rings, just in case.
bigblockyeti is offline
post #5 of 6 (permalink) Old 05-24-2019, 02:33 PM
Sabre-t's Avatar
Color: Red/Black
seals and o-rings get old. the calipers can start leaking, sticking, or outright fail. kawi manual for voyager recommends rebuilding every 4 years or 30k miles. not excessive in my opinion. if your brakes fail you at a critical moment...
Installed:
Longer Kickstand
Dobeck EJK 3.0
Wiring for Trailer
Ray's Throttle Mod
Things to do:
LET'S RIDE
Sabre-t is offline
post #6 of 6 (permalink) Old 05-25-2019, 08:00 AM
oldbeezer's Avatar
Year/Make/Model: 2012 Vulcan Nomad
Color: green/black
as the pads wear more of the piston is exposed where it will collect more brake dust (it is abrasive) which then wear the seals etc.
oldbeezer is offline
Vulcan 650 S starting problems Miguel Vulcan 650 S 16 06-20-2018 09:43 PM
Starting and smoking zuritap Vulcan 750 10 04-04-2014 02:39 AM
Need help with 1993 vulcan 88 1500 not starting. not cranking. bigsteveo Vulcan 1500 32 03-04-2012 08:12 PM
Help!!! Starting problem Help!!! Paul Terrill Vulcan 2000 11 08-19-2011 02:59 AM
Starting problems Gershwin Vulcan 1500 9 11-07-2010 10:25 AM
