Cruise Control Issue - Kawasaki Vulcan Forum : Vulcan Forums
 7Likes
post #1 of 12 (permalink) Old 05-20-2019, 11:30 PM Thread Starter
I just got a new (new to me) 2012 Vulcan Voyager today and I'm super excited. The bike rides like a dream! My only issue is with the cruise control. I've emailed the previous owner and haven't heard back yet so I figured I'd give my question a shot in here.
I took the bike out on the open highway for a bit today. I was doing about 70 and tried to set the cruise control it but it wouldn't take. The Cruise button was pressed-in and the light came on in the dashboard but when I tried to set a speed it wouldn't take. No matter how many times I pushed on the Set lever it wouldn't engage. Any ideas?
Adam Sternberg is offline
post #2 of 12 (permalink) Old 05-21-2019, 12:53 AM
Peg
Peg's Avatar
The usual culprit is the micro-switch on the rear brake pedal. A little WD40 and a clean of that switch is often enough, sometimes adjustment is required. There are other micro switches on the throttle, and the clutch and brake levers, and there is a diagnostic routine outlined from page 692 in the workshop manual to go through to accurately identify the issue.
Co0terV2K likes this.
Paul (Peg) Elliott
Peg is offline
post #3 of 12 (permalink) Old 05-21-2019, 01:15 AM Thread Starter
Just went and took a look. The switch for the rear brake seems to be just fine. Plenty of pressure on it when the brake is not in use. However, the switch on the front brake lever seems VERY sensitive. Like barely any pressure and I hear it click. I wonder if the highway speeds are just enough to push it back and disengage the switch?
post #4 of 12 (permalink) Old 05-21-2019, 04:30 AM
Peg
Peg's Avatar
There are two switches... Make sure you're not confusing the one for the brake lights with the one for the Cruise? Otherwise, maybe you should do that diagnostic thing to confirm where the fault actually is.
Paul (Peg) Elliott
Peg is offline
post #5 of 12 (permalink) Old 05-21-2019, 05:04 AM Thread Starter
Can you please be a bit more specific? The manual you sent me the link to does not have a page 692 in it. All of the pages are organized by sections, not page numbers. Sorry, I can't send PMs yet. My account is too new.
post #6 of 12 (permalink) Old 05-21-2019, 07:46 AM
Year/Make/Model: 2016 Voyager 1700
If you open it up with adobe the page numbers are at the very top in the adobe program. Ignore the section numbers etc and look for the pages in the very top bar their are over 700 pages. Good luck.
mike07-16 is offline
post #7 of 12 (permalink) Old 05-21-2019, 10:24 AM Thread Starter
Got it. I ran through the diagnostic and it says it's the clutch switch. I'm not sure if there is an adjustment for that or if I need to buy a new switch?
post #8 of 12 (permalink) Old 05-22-2019, 12:34 PM
I had the same problem. Found the clutch switch to be the issue. All I have done at this point is push the clutch lever forward after shifting and away the cruise goes. Will have to look into replacing the switch some day
Kevin
kmac1 is offline
post #9 of 12 (permalink) Old 05-22-2019, 02:00 PM
Year/Make/Model: 1999 Kawasaki Vulcan Nomad
Displacement/CC's: 1500
Color: Red\Maroon
I had this issue with my Vaquero, but I had a get back whip on the brake lever. It was enough movement that it would engage the lever. I am looking at adjusting the lever.
Turtleboy4329 is offline
post #10 of 12 (permalink) Old 05-28-2019, 01:53 PM Thread Starter
Turns out it wasn't a switch issue at all. It was nothing more than a bushing in the clutch handle that had just worn out, causing enough wiggle in to disengage the switch.
Nixoninc, Peg, Co0terV2K and 1 others like this.
Cruise control won't set anymore Hulk cowboy Vulcan 1700 11 10-01-2013 07:55 AM
BRAKEAWAY CRUISE CONTROL 4 Sale Hdsteal Bike Parts, exhausts, etc. For Sale 4 08-01-2013 10:11 PM
Cruise Control johnwh48 Vulcan 900 13 01-14-2010 06:32 AM
Vista cruise control install question??? accordpower99 Vulcan 800 5 09-17-2009 02:45 PM
Installed vista cruise control now hard starting?? accordpower99 Vulcan 800 1 09-15-2009 08:36 PM
