Vaquero wobble - Kawasaki Vulcan Forum : Vulcan Forums
 6Likes
post #1 of 12 (permalink) Old 05-16-2019, 06:12 AM Thread Starter
marcelm's Avatar
Year/Make/Model: 1995/Kawasaki/VN800A
Displacement/CC's: 800
Color: black
Vaquero wobble
Hello,
My buddy has an Vaquero.
When he rides at 70 mph, all is OK, he can even take the hands out from the handlebar, the bike is running straight, with no issue. But if he increase the speed to about 80 mph, the bike starts to wobble. Itís not a front wheel wobble, itís a complete bike wobble.
The bike started to do this, since he changed the tires (both tires). The tires are balanced.
Did somebody experienced such thing ?
Marcel
marcelm is offline
post #2 of 12 (permalink) Old 05-16-2019, 06:14 AM
Tires could still be unbalanced at 80. I used airsoft bbs to balance mine and they have never been so smooth at any speed
Sent from my SM-N950U using Tapatalk
marcelm and bearslayer like this.
ksgjlg is offline
post #3 of 12 (permalink) Old 07-08-2019, 07:38 AM Thread Starter
marcelm's Avatar
Color: black
Problem not solved ..
After doing some research ... it is not wobble, it is weaving !! And is a known phenomenon, specialy for big bikes.
The wheels were balanced again, but no improvement.
Next step is to try the the beads balancing.
marcelm is offline
post #4 of 12 (permalink) Old 07-08-2019, 03:05 PM
Year/Make/Model: 2016 Kawasaki Voyager; 2004 VFR800; 2003 VTX 1300
Color: Phantom/Spark
Don't rule out the tires. My new metzeler front tire caused a hell of a wobble. Hands-on the bars, wobble started around 35 and with both hands on would wobble up to around 50....couldn't even consider riding with only one hand or checking decel wobble with no hands. To be clear, I have had good luck with Metzeler on multiple bikes in the past so I disregarded logic and thought my problem was elsewhere....perhaps the newer stem bearings loosened up or a rear end problem. Well, after a good bit of unnecessary work redoing the stem bearings, rebuilding front
suspension, adjusting rear suspension & checking alignment of everything turned out the new front tire was the problem. New michelin and can ride hands free for miles.
If the you are positive the tires are good - Check stem & suspension adjustments. The 1700's suspension is soft from the factory and if the rear shocks are pumped up a good bit but the forks haven't had any love (springs/spacers) the attitude of the chassis (front/rear weight bias) could be less than ideal. Raising the rear and/or dropping the front makes it steer quicker but the resulting changes rake & trail numbers tends to induce stability problems at higher speeds.
marcelm likes this.
"A good long ride can clear your mind, restore your faith, and use up a lot of fuel"
"I believe in treating everyone with respect, but, first you have to get their attention"
Never be ashamed to unlearn an old habit...
gearhead759 is offline
post #5 of 12 (permalink) Old 07-09-2019, 07:38 AM Thread Starter
marcelm's Avatar
Color: black
Yes, probably you are right. Thank you for your input.
The problem started after changing the tires to Avon Cobra. In addition to this, I have another friend with an VN1600 => he has the same problem of weaving after changing the tires to Avon !!!!!! I could not believe ..... (Weaving, not wobble)
Our plan is :
1. try the balancing beads => easy to do. If no effect :
2. change tires
I will post here to keep you updated.
marcelm is offline
post #6 of 12 (permalink) Old 07-10-2019, 07:52 PM
Use airsoft bbs. Cheap and mine has never been smoother
marcelm likes this.
ksgjlg is offline
post #7 of 12 (permalink) Old 07-11-2019, 01:22 AM Thread Starter
marcelm's Avatar
Color: black
How to measure the proper quantity ?
marcelm is offline
post #8 of 12 (permalink) Old 07-11-2019, 03:53 AM
A bottle of airsoft from Walmart is 8oz. According to the dynabeads chart you need about 2oz for the front stock tire so 1/4 of the bottle. Divide in half then half again. I have a 195/60 car tire on the back. Chart says 3oz so half of what is left. Make sure you DON'T get the biodegradable beads. The only downside to the airsoft beads is you have to break the bead and put them in via the side since they won't fit in the stem.
marcelm likes this.
ksgjlg is offline
post #9 of 12 (permalink) Old 07-11-2019, 04:09 AM Thread Starter
marcelm's Avatar
Color: black
Thanks, will do so.
marcelm is offline
post #10 of 12 (permalink) Old 07-11-2019, 09:34 PM
By the way, I looked at my bottle and it doesn't say 8oz. It says 2000 bbs at .12gm.
.12x2000=240gm=8.466oz...close enough
ksgjlg is offline
Vaquero front end wobble IL Vaquero Vulcan 1700 67 04-07-2016 05:10 AM
developed a wobble?? RuaphuNZ Vulcan 2000 16 01-18-2014 08:05 PM
Mild front end wobble stripperguy Vulcan 900 21 09-30-2013 08:38 PM
Vaquero 21" wheel wobble Law369 Vulcan 1700 6 04-05-2013 08:35 PM
VN900 - Rear pulley Wobble - a simple fix... Denis Vulcan 900 10 05-14-2012 06:17 PM
