Squeaks and chirps from the tank - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 6 (permalink) Old 05-09-2019, 07:59 PM Thread Starter
VulcanDan61's Avatar
Year/Make/Model: 2011 Nomad
2011 Nomad. Had a shop on a new front tire, all balls bearings, and fix a front light. I am sure they took the tank off for at least one of these. Now when I hit anything remotely rough, like coarse pavement, I get funny squeaks and chirps from the tank. Is it possible they screwed up replacing the tank? Is there some kind of gasket in there that they replaced wrong?
Maybe I’m speculating. It’s really irritating, however. But the all balls bearings are great!
Happy and safe riding,
Dan
2011 Nomad: Black & Metallic Gray, Chuckster's Light Bar, Rac'nRay's Throttle Mod, Homemade Oversize Lowers, Kawasaki Trunk, Ivan's Flash
Past:
2014 900 Classic LT: (Sold to a happy buyer)
1975 Suzuki GT 185 (Great little twin)
VulcanDan61 is offline
post #2 of 6 (permalink) Old 05-09-2019, 08:41 PM
Year/Make/Model: 2018 Kawasaki Voyager
Color: Red
Sounds like the same issue I had with my new Voyager and it drove me nuts. Turned out to be two easy fixes as itís probably the trim around the ignition rubbing on the metal tank bib and the metal bib rubbing on the tank.
- lift the metal bib and lay some insulation tape between it and the tank
- press down on the round metal ignition trim to ensure its fully seated.
Disco42 is offline
post #3 of 6 (permalink) Old 05-10-2019, 06:41 AM
CarGuy's Avatar
Year/Make/Model: 2014 Nomad ABS
Color: Black/White
My 2014 Nomad did the same when it was new. Really annoying! The plastic meter cover was rubbing against the fuel tank. The dealer stuck two soft rubber spacers on the fuel tank to keep the cover off the tank. Here's a pic from the side. You can see the spacer under the arrow. There's one on each side. I haven't had a problem since they added these over 33,000 miles ago.
Go for the ride!
2014 Kawasaki 1700 Nomad ABS
2008 Kawasaki 900 Classic LT (sold 2015 42k miles)
1975 Kawasaki KZ400 (sold ~1985)
1970 Suzuki TS250 Scrambler (stolen 1971)
1968 Bridgestone 200 MKII RS (sold 1970)
Patriot Guard Rider
USN 1971-75
CarGuy is online now
post #4 of 6 (permalink) Old 05-12-2019, 08:04 AM
IDONTWANTO's Avatar
My nomad does the same. I havent tried a fix yet but it seems to go away when I push down on the trim around the key switch like the other guy says.
IDONTWANTO is offline
post #5 of 6 (permalink) Old 05-15-2019, 09:21 PM
Year/Make/Model: 2018 Kawasaki Vulcan Voyager
Color: Red
I slipped a thin piece of inner tube under both sides of the tank bib, at the very front where it turns down. Solved the problem easy and free.
Randy
East Texas
Farmboy65 is offline
post #6 of 6 (permalink) Old 05-16-2019, 08:39 AM
Year/Make/Model: 2015 Voyager
Color: Black/Gray
When I took off my tank strap, I noticed a couple of large rubber isolators. One had come loose. I had some thick foam rubber stick-on weatherstripping, so I used that, all along the inside of the plastic strap. I also put some inside the fairing pocket doors. Things quieted down after doing this.
Hathaway is offline
