Front wheel axle spacer question - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 3 (permalink) Old 04-26-2019, 07:36 PM Thread Starter
Twitchrope's Avatar
After changing the front tire and putting the wheel back on, i noticed that one spacer on the axle touches the fork and the other is about 3/32 short of touching the fork Took all apart and re assembled with the same result. Everything is as tight as it will go. And there is no movement in the spacer. Everything seems to move as its supposed to and theres no wobble or anything. Has anyone else experienced this?
Twitchrope is offline
post #2 of 3 (permalink) Old 04-26-2019, 07:39 PM
Peg
Peg's Avatar
It's an illusion. I remember thinking the same thing once, but if you remove the spacer you'll see it's hard up against a smaller diameter collar around the axle shaft hole in the fork.
Paul (Peg) Elliott
Peg is offline
post #3 of 3 (permalink) Old 04-26-2019, 08:02 PM Thread Starter
Twitchrope's Avatar
Thanks Peg. Appreciate the info!!
HD front wheel mod- alignment. TrentonC Vulcan 2000 12 05-04-2017 10:49 AM
09 classic noise from front wheel bearing? Drummer87 Wheels and Tires 0 08-13-2016 09:33 PM
front Wheel 21" bernie Vulcan 1700 0 01-13-2014 12:59 PM
front wheel swap sunnybob Vulcan 800 2 10-28-2013 12:55 AM
Odd Noise front wheel Hatchcover Vulcan 900 14 09-23-2012 07:28 PM
