Auxiliary Power Connections - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
  • 1 Post By VulcanRide
post #1 of 10 (permalink) Old 04-20-2019, 09:21 AM Thread Starter
Year/Make/Model: 2018 Kawasaki Voyager
Color: Red
In my quest to upgrade I now have more devices than auxiliary power connectors (electric gloves, gps, dual USB ports). Has anyone run an additional fuse box? Also, any idea what size the spade lug is for the aux connectors as I have various sizes and none seem to fit these connectors (proprietary??). Thanks
Disco42 is offline
post #2 of 10 (permalink) Old 04-20-2019, 07:15 PM
whoaru99's Avatar
Check at easternbeaver dot com.
whoaru99 is online now
post #3 of 10 (permalink) Old 04-20-2019, 08:20 PM
Sabre-t's Avatar
Color: Red/Black
The spades in the fairing are very large. I don't have the size handy now.
I don't have this one (YET) but this fusr block looks freakin' awesome https://www.advdesigns.com/fuzeblock...yABEgLG__D_BwE. Keyed or always on options for every slot. Common ground strip.
I have used something like this for the fairing connectors:
Installed:
Longer Kickstand
Dobeck EJK 3.0
Lucky Mirror Extenders
Wiring for Trailer
Ray's Throttle Mod
Things to do:
LET'S RIDE
Sabre-t is offline
post #4 of 10 (permalink) Old 04-24-2019, 10:11 AM
VulcanRide's Avatar
I think you are talking about the 10 amp accessory plugs, one under the seat and the other behind the headlight are designed to use bullet connectors (two in each plug) or you can use a single spade but it is not designed for that.
_______________
__________
_____
Vulcan, the Roman god in charge of fire and metallurgy.
'05 Vulcan 2000 - Gone to the car gods
'16 Vulcan 1700 Voyager - New in 2017
IBA #39104
VROC #30249
VulcanRide is offline
post #5 of 10 (permalink) Old 04-24-2019, 01:20 PM
Sabre-t's Avatar
Color: Red/Black
i didn't realize they were dual bullets. i had some large spades w/ rolled edges tat fit perfectly. maybe the plug they used is intended to worked both ways by the plug oem. thanks.
Installed:
Longer Kickstand
Dobeck EJK 3.0
Wiring for Trailer
Ray's Throttle Mod
Things to do:
LET'S RIDE
Sabre-t is offline
post #6 of 10 (permalink) Old 04-24-2019, 01:45 PM
VulcanRide's Avatar
Sabre-T I never could find a spade big enough so I just used the normal size until last year I was watching a video and the guy just said it in passing. I went out to the bike and sure enough a bullet works perfect.
I would also suggest that when you are adding USB ports to the bike you need to look at the output amps, new phones and some other devices like to have 2+ Amp so you can operate them as well as charge them.
Most cars have 1.x amps so if you are using your phone for navigation it will not charge and in some cases slowly drain the phone. I added a volt meter/dual USB and it is rated at 4.2 amps 2.1 per USB.
Peg likes this.
_______________
__________
_____
IBA #39104
VROC #30249
post #7 of 10 (permalink) Old 04-24-2019, 08:27 PM
Sabre-t's Avatar
Color: Red/Black
Sabre-T I never could find a spade big enough so I just used the normal size until last year I was watching a video and they guy just said it in passing. I went out to the bike and sure enough a bullet works perfect.
i run most accessories off my own key powered fuse block or their own relays. i have had too many problems w/ phones running anything but BT for gps and music and trying to charge. overheating. so i usually do charge at 1 amp and turn off music if btty can't keep up w/ 1 amp charging.
i don't remember the spade size but i had a couple left over after a welder, stove or some hev duty repair.
i like the panal you made, especially the heated gear controls. did you have to dismantle them to make the lights poke thru? any weatherproofing?
Installed:
Longer Kickstand
Dobeck EJK 3.0
Wiring for Trailer
Ray's Throttle Mod
Things to do:
LET'S RIDE
Sabre-t is offline
post #8 of 10 (permalink) Old 04-24-2019, 10:21 PM
VulcanRide's Avatar
Thanks, I used the Gerbing Dual Permanent Temp-Controller, only thing I would do different is mount the lights at 3 o'clock and not 12 as it is hard to see if they are on when riding but not that big of a deal. I run the heated gear off of the 10 amp auxiliary from behind the headlight, have run two vests and gloves and didn't have an issue. The USB is from a fused line I run to a block behind the headlight so I can have it on anytime I want and my garage door opener is also wired to the always on.
FYI you garage door opener runs off a small 12v battery, I wired it to my motorcycle battery and I can open the garage another 30 feet from the house and never worry about the battery going dead.
_______________
__________
_____
IBA #39104
VROC #30249
post #9 of 10 (permalink) Old 04-25-2019, 12:32 AM
Peg
Peg's Avatar
I just stuffed a modified "always on" (jumped across the terminals) 12v garage door opener into a plastic zip-lock bag, taped the bag into my fairing, and soldered wires from where the batteries used to be - to ground, and to my headlight high-beam wire.
No button required. I just flash my garage with high-beam, and the door goes up, or down.
But I certainly do like that work you've done to your leg shield there... Mine contain a dual tone car horn each side, which leaves little room for anything else.
Paul (Peg) Elliott
Peg is offline
post #10 of 10 (permalink) Old 04-25-2019, 09:37 AM
VulcanRide's Avatar
My dad always told me to never attach anything to the headlight circuit, if you blow the fuse at night because what you add can be very dangerous.
Thank you, I use Microsoft Visio and a scanner, put the part in the scanner then take the image into Visio and lay out the parts, print the template and then tape it to the scanned part (scan is to exact scale) and then make your holes and you are done.
Not fair, you are making me jealous with the horns. I added the Wolo bad boy but still need more.
_______________
__________
_____
IBA #39104
VROC #30249
need help please! no power on motorcycle at all! hfire333 New Member Introductions 5 06-09-2014 08:57 AM
no electrical power kardenm Vulcan 1600 5 05-09-2014 02:51 PM
Power Pucks Lunatic General Vulcan Talk 0 02-12-2014 09:11 AM
05 Power diminishes as engine heats up labeledbass Vulcan 500 13 06-04-2011 10:03 PM
