Classic LT Belt Guard bolts - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 7 (permalink) Old 03-19-2019, 08:55 PM Thread Starter
DrugerH's Avatar
Year/Make/Model: 2009 Kawasaki Vulcan 1700 Classic LT
Color: Green/Beige
Good evening all, I pulled my bike out of the garage this weekend after a long Wisconsin winter, and I noticed that, on the frame, above the belt, there are two brackets that looked like something should be bolted to it. I never noticed it before, so not sure why I did now. Anyhow, I went online to see what I was missing. Yup, you guessed it, the belt guard.
I looked on eBay and was able to purchased a used OEM belt guard for just below $15. There are, however, no bolts with it, nor are there any bolts on the bike for this. So, my question is, what type and size of bolts do I need to bolt it back to the bike?
P.S., I think the shop that replaced my rear tire last year may have not replaced the belt guard, but at the same time, I don't recall ever having it on the bike. So, I may have purchased it that way.
Dan
DrugerH is offline
post #2 of 7 (permalink) Old 03-20-2019, 10:13 AM
rozie's Avatar
Year/Make/Model: 2015 Vulcan Vaquero ABS SE
Displacement/CC's: 1700cc
Color: metalic carbon grey
on my vaquero there is no need to remove the belt guard to take the rear wheel off so if yours was missing it was probably not there when you purchased the bike, either way thats a good price on a OEM part. as for the bolt size, if you have a set of drill bits, try putting a few in the holes until you find one that just fits and look at the size of that one. now you know what size bolt you need. if it were me I would get stainless bolts with nylock nuts. no need for loctite and they wont rust.
2015 vaquero ABS SE {carbon grey}
12in. windshield
k&n air filter
freedom performance true duals
ivans ecu flash
kuryakin longhorn cruise pegs
sagebrush saddlebag chaps
oem aux lights
grasshoper driver backrest
black isso grips
chucksters risers
isso grip helmet locks
rozie is offline
post #3 of 7 (permalink) Old 03-21-2019, 04:39 AM
SteveJB's Avatar
Displacement/CC's: 1700 cc
Color: Candy Cardinal Red
The Vaq only has a lower guard but the classic also has an upper guard. The upper guard needs to come off so you can handle the belt.
SteveJB is offline
post #4 of 7 (permalink) Old 03-21-2019, 11:27 AM
Archie's Avatar
Year/Make/Model: 2010 Kawasaki Vulcan 900 Classic LT
Displacement/CC's: 900
Color: Blue/Grey
Go to any online store that sells OEM parts and look them up , then buy the same size in stainless steel
Archie is offline
post #5 of 7 (permalink) Old 03-22-2019, 08:03 AM
tcheekva's Avatar
The bolts you need are listed on this page. https://www.ronayers.com/oemparts/a/...rs-chain-cover
bolt-6x18 OEM part number 92153-0816 $0.95 each
2009 Classic LT 1700 avg 38mpg
Added factory cruise control
Converted to nomad exhaust
V&H Twin Slash Cut slipons
USA Trailer Store Fairing
HD Tour Pack
Avon Grips
Kuryakyn LongHorn Pegs
Mustang Wide Touring w/studs backrest
Throttle Body Gasket
Thunder Mfg OEM Cover BAK
Pipes wrapped
Ivans ECU Flash
Custom Trailer Hitch
tcheekva is offline
post #6 of 7 (permalink) Old 03-29-2019, 08:15 PM
IDONTWANTO's Avatar
I recommend bikebandit.com
IDONTWANTO is offline
post #7 of 7 (permalink) Old 03-29-2019, 11:32 PM
Year/Make/Model: 2009 Vulcan 900 LT
Color: Red/Silver
I love the information and experience you all share. Thank you.
I'm going in the garage and look at my belt guards. I think I'll take pictures now so I can tell if something is missing later.
Shorty68 is offline
Issue mounting Viking bags on 900 Custom RoadRunner500 Vulcan 900 35 07-24-2019 12:33 PM
Drive Belt Position Pics after adjustment. DarkCruzer Vulcan 900 32 06-04-2015 10:16 PM
Airlite engine guard: Vulcan 1600 classic Hdsteal Bike Parts, exhausts, etc. For Sale 1 01-12-2013 10:45 PM
belt adjustment issues bogbard Vulcan 900 14 06-10-2011 07:41 AM
Belt Drive on a 800 Classic 800Rider Vulcan 900 7 09-30-2008 10:52 AM
