Engine Oil - how much? - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
  • 1 Post By Shawn Graham
post #1 of 3 (permalink) Old 02-26-2019, 08:46 AM Thread Starter
Looking at the manual for Voyager 1700, it indicates that when oil filter is removed it requires 4.3L, but when engine is completely dry 5.0L
So, which is it? When you change the oil does it drip out enough to remove the remaining .7L ? So do i count on requiring 5L ?
Was going to order some Amsoil, they come in 946ml containers or 3.78L bottles, so trying to figure out how much i should order.
Maybe i should get 3 of the 3.78L, give me 2 changes?
Shawn Graham is offline
post #2 of 3 (permalink) Old 02-26-2019, 09:31 AM
rozie's Avatar
Year/Make/Model: 2015 Vulcan Vaquero ABS SE
Displacement/CC's: 1700cc
Color: metalic carbon grey
I did my 6th oil change in november/18 at 5000 klm intervals. remember these 1700s have 2 drain plugs. when I drain mine I put a 2x4 under the side stand to get the bike more level then pull the drain plugs and take the oil filter off while the drain plugs are still out. then I pull the bike up off the side stand ( or you can sit on it ) and you can see more oil comming out of the drain holes. put the plugs back in with a new filter and put 5 ltrs of your favorite oil in. when I check the oil after a warm up, its always about a 1/4 of an inch under the full mark on the dipstick. one more thing. when you fill it with oil pour it in really slow or you might find that it will over flow.
2015 vaquero ABS SE {carbon grey}
12in. windshield
k&n air filter
freedom performance true duals
ivans ecu flash
kuryakin longhorn cruise pegs
sagebrush saddlebag chaps
oem aux lights
grasshoper driver backrest
black isso grips
chucksters risers
isso grip helmet locks
rozie is offline
post #3 of 3 (permalink) Old 02-26-2019, 10:06 AM Thread Starter
Thanks. SO it does take 5 liters. OK then..
Demoliton Man likes this.
V2K oil jimmytinknocker Vulcan 2000 9 04-04-2019 05:49 PM
Amsoil Slick8609 Vulcan 1700 36 11-07-2013 09:33 AM
First oil change milleage? evodog Vulcan 900 40 09-18-2012 03:48 PM
How do you check the oil level on vn2000 Drill Vulcan 2000 3 06-30-2011 11:26 PM
Oil In My Air Filter AEROFARM Vulcan 2000 19 09-25-2010 07:18 AM
