Air Shock Pump - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
  • 1 Post By auwing1978
post #1 of 8 (permalink) Old 02-20-2019, 07:40 AM Thread Starter
auwing1978's Avatar
Year/Make/Model: 2016 Voyager 1700 ABS
Color: Black-Silver
Send a message via AIM to auwing1978 Send a message via MSN to auwing1978
Air Shock Pump
I wish now I had bought this $25 pump when I first bought my 2016 Voyager. Turns out there was zero psi in both shocks. I put in 25 psi with back wheel off the ground. Will play with it as needed.
bullcrapallday likes this.
When the going gets weird, the weird turn pro. HST
auwing1978 is offline
post #2 of 8 (permalink) Old 02-20-2019, 11:07 AM
I just bought this pump
Thing is..... Should it not take more pumps to get in 40PSI? I wanted to put in 15 so gave one pump and it went right up to 40psi?
Does that make sense?
Shawn Graham is offline
post #3 of 8 (permalink) Old 02-20-2019, 01:02 PM
bearslayer's Avatar
Year/Make/Model: 2004 Nomad , 1985 BMW K100 X2 , 1985 Intruder, 1998 Ducati Monster, 1972 CL350, 1948 Indian CZ125, 2
Displacement/CC's: 125 -1500
Color: Blue & Silver , Black , Gray , Maroon,black,
https://www.amazon.ca/gp/product/B00...?ie=UTF8&psc=1
Nope !!!!!!!!!! had to get 10 characters
That which does not kill me tends to really piss me off.
bearslayer is online now
post #4 of 8 (permalink) Old 02-20-2019, 01:51 PM
Year/Make/Model: 2015 Voyager
Color: Black/Gray
I have that pump - Harley sold it to me for my Road Glide. It looks like the exact-same pump sold by Kawasaki. I usually have to pump once or twice, then bleed it down to what I want for pressure. Used a bicycle pump for my Gold Wing!
Hathaway is offline
post #5 of 8 (permalink) Old 02-20-2019, 02:34 PM Thread Starter
auwing1978's Avatar
Color: Black-Silver
Nope....I had to pump mine many times to get to 25 psi
post #6 of 8 (permalink) Old 02-20-2019, 02:45 PM
Color: Black/Gray
I usually set mine at 10-12 psi. I get maybe 14 psi on 3 pumps. Maybe these are different pumps - they look the same to me.
Hathaway is offline
post #7 of 8 (permalink) Old 02-20-2019, 03:27 PM
Sabre-t's Avatar
Color: Red/Black
I would not think one pump stroke would increase the pressure anywhere near 25 psi. You may not have had it seated correctly or the pump port is not opening the schrader valve and what you measured was the increase in pressure between the shock valve and the check valve inside the pump. I have a different pump, but it only increases the shock pressure by a few psi per pump stroke.
Installed:
Longer Kickstand
Dobeck EJK 3.0
Lucky Mirror Extenders
Wiring for Trailer
Ray's Throttle Mod
Things to do:
LET'S RIDE
Sabre-t is offline
post #8 of 8 (permalink) Old 02-20-2019, 07:12 PM
Yea thatís the best one on the market I have found.
bullcrapallday is offline
Rear air shock balance Compton89 Vulcan 1500 10 09-30-2015 08:32 PM
Fitted Ohlins rear shock RuaphuNZ Vulcan 2000 9 07-28-2014 03:58 PM
Warm-up rpm to high after first start-up. Jeep Pirate Vulcan 900 10 10-09-2010 07:03 AM
Air Shock Pressure dlauffenburger Vulcan 1700 15 01-31-2010 06:40 PM
air shock balance kit on 1600 classic upstatecowboy Vulcan 1600 0 11-15-2009 02:09 PM
