Compression release not working - Kawasaki Vulcan Forum : Vulcan Forums
 2Likes
  • 2 Post By ksgjlg
post #1 of 10 (permalink) Old 02-17-2019, 07:40 PM Thread Starter
Bought a 2009 voyager with 25k miles. It sat up for about a year plus. Won't turn over. Took out the front plug and it turns over fine. Put plug back in and it won't turn over. New battery with 240cca. My guess is the compression release is not opening. Any suggestions other than pull the engine?
Sent from my SM-N950U using Tapatalk
ksgjlg is offline
post #2 of 10 (permalink) Old 02-18-2019, 07:58 PM Thread Starter
For anyone interested. Put half a quart of marvel mystery oil in and took plug out. Ran starter for about 20 seconds several times to pump oil into the compression release valve. Valve now working properly turns over as it should with plugs in
Peg and bullcrapallday like this.
ksgjlg is offline
post #3 of 10 (permalink) Old 02-18-2019, 10:11 PM
Peg
Peg's Avatar
Glad you found a solution. Everyone else in here likes to start their bikes at least once a year, so you're probably among a very small group of riders to experience this difficulty.
Paul (Peg) Elliott
Peg is offline
post #4 of 10 (permalink) Old 02-20-2019, 07:13 PM
Thatís a new one.
bullcrapallday is offline
post #5 of 10 (permalink) Old 02-20-2019, 08:14 PM
Compression release would not be accessible through the spark plug hole to Marvel mystery oil. They are on the ends of the camshafts,
Something else going on there.
sfair is offline
post #6 of 10 (permalink) Old 02-20-2019, 08:33 PM Thread Starter
You take the plug out so it will turn over since there is no compression. That allows oil to flow up to the camshaft and oil the release valve.
ksgjlg is offline
post #7 of 10 (permalink) Old 02-20-2019, 09:41 PM
It is not a valve itself. It holds exhaust valve open a slight amount using a series of springs and weights. Nothing that Mystery oil would fix.
sfair is offline
post #8 of 10 (permalink) Old 02-21-2019, 03:27 AM Thread Starter
It's a moving part that obviously wasn't moving. Once oil was pumped up in the area where that is located it began to function as it should.
ksgjlg is offline
post #9 of 10 (permalink) Old 02-21-2019, 03:29 AM Thread Starter
And the weights and spring actuate a valve, a compression release valve.
ksgjlg is offline
post #10 of 10 (permalink) Old 02-21-2019, 09:46 AM
They do not actuate a "release valve"...that is not how it works.
But in any case, you "lost" the condition and that is what counts, maybe.
sfair is offline
compression release phsh7777 Vulcan 1500 8 06-12-2018 10:57 PM
Compression Release Problems? papayadialog Vulcan 1500 12 11-22-2017 12:32 PM
possible sticking compression release? mcoffroad2003 Vulcan 1500 9 05-12-2014 06:11 PM
compression release? 2tonbuick General Vulcan Talk 5 05-28-2009 07:12 AM
