Temp - Kawasaki Vulcan Forum : Vulcan Forums
 2Likes
  • 1 Post By SteveJB
  • 1 Post By stessel
post #1 of 5 (permalink) Old 01-09-2019, 10:46 AM Thread Starter
Temp
So ive got a 2015 Vaquero. It has no mods. Im up at 6500 ft elevation with ambient temps around 60f. This bike seems to run hot any time its not going down the road at hwy speed. Anytime in stop and go or at long signals it hovers at the 3/4 mark.
Is that normal? And, what can i do to cool it down?
dvc357 is offline
post #2 of 5 (permalink) Old 01-09-2019, 11:14 AM
SteveJB's Avatar
Displacement/CC's: 1700 cc
Color: Candy Cardinal Red
I have a 2017 Vaquero and had to ask the same question last year. That is normal. As far as cooling it down, I was told to:
  • Try a different anti-freeze (like Engine Ice).
  • Get a heat shield (I have a nice leather one that helps a bit)
  • Remove the lower fairing in hot weather
  • Ivanize the ECU (apparently the best option)
Hope this helps. The leather heat shield is the only thing I've tried so far. It does work, but you still get a lot of hot air directed at your thighs.
Demoliton Man likes this.
SteveJB is offline
post #3 of 5 (permalink) Old 01-09-2019, 12:33 PM
Year/Make/Model: 2016 Voyager 1700
Color: Grey/Black
I have a 2016 with KAMS and don't notice the temps burning up my legs and such the way my Warrior does. But I have noticed same on the indicator being at the 3/4 mark. As soon as I hit the highway it seems fine again.
Everything I have read says that part of the Ivan ECU flash lowers the temp that the fans kick on so it keeps things running cooler.
-Rob
2016 Voyager
2007 Yamaha Warrior
RobRiguez is offline
post #4 of 5 (permalink) Old 01-09-2019, 05:14 PM
stessel's Avatar
Year/Make/Model: 2016 Kawasaki Voyager
Color: MetalicBlackk/Silver
Hey, Yep the Vulcan 1700 bikes just run. I live in Louisiana where it really gets hot in the summer and the temp gauge prior to Ivan flash would set at 1 tick mark before the red line. Since the Ivan flash it does help now it runs just past 2 tick marks prior to red line in the summer. When it is cool out 60-70 it will run in the middle.
SteveJB is right for heat deflection the leather heat deflector that goes under the seat just behind the tank makes all the difference in the summer and your sitting at a red light I highly recommend both the deflector you can find on ebay https://www.ebay.com/itm/PLAIN-LEATH...frcectupt=true and Ivan's flash (worth the money0
stessel is offline
post #5 of 5 (permalink) Old 01-09-2019, 09:39 PM
auwing1978's Avatar
Year/Make/Model: 2016 Voyager 1700 ABS
Color: Black-Silver
Send a message via AIM to auwing1978 Send a message via MSN to auwing1978
Ivanizing, highway pegs, Duluth Trading Co. Ballbuster jeans (trust me) and the leather heat deflector sure help on a very hot day. I frankly only notice the heat on my 2016 Voyager when temps are approaching/over 90 F and am in stop/go traffic or sitting at t traffic light.
When the going gets weird, the weird turn pro. HST
auwing1978 is offline
Water Temp/Oil gauge lights Grumpynuts Vulcan 500 6 09-20-2011 07:18 PM
voyager running temp motodoc43 Vulcan 1700 16 04-12-2010 08:48 PM
oil pressure/water temp gauges Skidaddle Vulcan 1600 2 09-01-2009 05:58 PM
Cooling Fan Temp Switch Tiger Rag Vulcan 1600 0 06-22-2009 08:22 PM
air temp sensor 1500 classic fi MIRTO88 Vulcan 1500 9 05-22-2009 09:19 PM
