Clutch Master rebuild - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 4 (permalink) Old 12-28-2018, 11:59 AM Thread Starter
Color: Red/Black
I didn't find anything on this forum about rebuilding the clutch master cylinder so sorry if this has already been discussed. I'm working on my 2010 Voyager 1700 non ABS. I want to rebuild the Clutch master cylinder but I can't seem to find a rebuild kit that says it is for this bike. I know people out there have rebuilt the clutch master. What rebuild kit did you use? Is it the same kit for the front brake master?
Any and all help is appreciated.
JaBooty is offline
post #2 of 4 (permalink) Old 12-28-2018, 01:57 PM
Year/Make/Model: 2000 Nomad 1500 fi
Displacement/CC's: 1500
Color: Purplish Black Mica
See if this may be of help to you...
https://www.ebay.com/itm/2009-2013-K...4383.l4275.c10
Ride Hard, Ride Safe
RetroBagger is offline
post #3 of 4 (permalink) Old 12-28-2018, 03:20 PM Thread Starter
Color: Red/Black
Thanks for the reply. I will order that and give it a try. I like the idea of replacing the rubber components of the slave cylinder also. I will post again once I have rebuilt the clutch line and components.
JaBooty is offline
post #4 of 4 (permalink) Old 01-02-2019, 09:04 AM
RACNRAY's Avatar
Flushing AND bleeding of ALL the hydraulic systems on a regular basis will prevent or minimize the need for rebuilding the components. In our South Florida humid environment, or any humid area, flushing and bleeding once a year helps to correct the normal deterioration of the fluid. No matter where you are flushing/bleeding the clutch system should be done once a year due to engine heat and it's affect on the fluid.
I put 100,031 miles on my Vaq in 5 years, and with regular hydraulic system maintenance never had any issues, and even better my 2000 Hayabusa finally had to have the rear m/c rebuilt when it was 17 years old with over 70,000 miles. Front m/c is still good.
RACNRAY
"TRUE HAPPINESS IS IN THE HEART,NOT IN THE OUTSIDE FIXES!!"
WITH OVER 42 YEARS AS A MOTORCYCLE TECHNICIAN/HI-PO SHOP OWNER I AM A PURVEYOR OF FACT NOT FICTION!
"WE LIVE OUR LIVES IN CHAINS NEVER KNOWING WE HAD THE KEY"
RACNRAY is offline
to rebuild, or not to rebuild phsh7777 Vulcan 1500 9 11-25-2018 10:23 PM
Clutch Master & Slave Rebuild Tips _Kodiak_ Vulcan 1500 20 02-09-2018 08:05 PM
difference between a clutch master cylinderand brake master cylinder daremoe63 Vulcan 1500 6 05-28-2015 12:18 PM
Clutch Master Cylinder rebuild bultaco4ever Vulcan 1500 14 07-28-2013 09:39 PM
master cylinder rebuild kit jeff5 Vulcan 500 1 05-24-2012 03:11 PM
