10w50 - Kawasaki Vulcan Forum : Vulcan Forums
 7Likes
  • 2 Post By H_A_N_S
  • 2 Post By vulcandoc
  • 1 Post By scorpionsix
  • 1 Post By H_A_N_S
  • 1 Post By Sabre-t
post #1 of 9 (permalink) Old 11-18-2018, 10:16 AM Thread Starter
marcelm's Avatar
Year/Make/Model: 1995/Kawasaki/VN800A
Displacement/CC's: 800
Color: black
10w50
Hello,
I have read into this forum that 20W50 is too thick at cold start and 10W40 too thin for hot summers.
Is the 10W50 a better solution ? so that we can satisfy both of the above "issues"
Does anybody use this oil grade ? From theoretical point of view seems the best option.
Bike is 1700 Vaquero.
Marcel
marcelm is offline
post #2 of 9 (permalink) Old 11-18-2018, 01:39 PM
H_A_N_S's Avatar
Year/Make/Model: 2018 Kawasaki Vulcan S 650
Displacement/CC's: 650
Color: Black
20W-50 is just fine if you don't use bike often at temperatures under 0C.
Sent from my SM-A510F using Tapatalk
marcelm and RetroBagger like this.
I'm just here for the gasoline.
H_A_N_S is online now
post #3 of 9 (permalink) Old 11-19-2018, 04:33 AM Thread Starter
marcelm's Avatar
Color: black
https://www.vulcanforums.com/forums/...20-50-oil.html
I was reading above topic, very old one. But, could not get to a clear conclusion.
marcelm is offline
post #4 of 9 (permalink) Old 11-19-2018, 07:05 AM
Color: Black / grey
The number before the "W" is for "winter" cold temps, and the oil has to be thinner to flow for the cold temps and start ups.
The second number is the weight for higher temps both engine and ambient temps.
So you will see in the manual to use 10w-30 and then if you're in hot temps use 10w-40.
If you're in the south and its always hot 20w-50 would most likely be fine, but check your manual.
marcelm and H_A_N_S like this.
vulcandoc is offline
post #5 of 9 (permalink) Old 11-19-2018, 09:35 AM Thread Starter
marcelm's Avatar
Color: black
I live in Romania, and drive mostly in the summer at around 15 - 34 degrees Celsius (59 - 95 F)
marcelm is offline
post #6 of 9 (permalink) Old 11-19-2018, 10:23 AM
Year/Make/Model: 2013 Nomad
Probably the most commonly oil used in these bikes is Shell's Rotella T6, a full synthetic 5w40. This product will serve you well in any climate.
marcelm likes this.
scorpionsix is offline
post #7 of 9 (permalink) Old 11-19-2018, 10:32 AM
H_A_N_S's Avatar
Color: Black
20W-50 will be ok.
Most of oils in this grade are mineral.
marcelm likes this.
post #8 of 9 (permalink) Old 11-21-2018, 10:59 AM
Sabre-t's Avatar
Color: Red/Black
I use 10W-40 for winter and 20W-50 for summer. I ride in temps down into the teens (F) in the winter and into the 100s in the summer and most years put on enough miles that I need 2 oil changes, minimum, anyway. For 50s to 90s, either 10W-40 or 20W-50 would be fine, but I think I would use 10W-40 if most of your riding will be below 90.
I don't know if you can get it there, but I really like Royal Purple Max Cycle oil. It comes in both weights and is fully synthetic.
marcelm likes this.
Installed:
Longer Kickstand
Dobeck EJK 3.0
Lucky Mirror Extenders
Wiring for Trailer
Ray's Throttle Mod
Things to do:
LET'S RIDE
Sabre-t is offline
post #9 of 9 (permalink) Old 11-22-2018, 05:50 AM Thread Starter
marcelm's Avatar
Color: black
Clear,
Thank you.
marcelm is offline
