air switch valve - Kawasaki Vulcan Forum : Vulcan Forums
 2Likes
  • 1 Post By rozie
  • 1 Post By Peg
post #1 of 3 (permalink) Old 11-15-2018, 12:07 PM Thread Starter
marcelm's Avatar
Year/Make/Model: 1995/Kawasaki/VN800A
Displacement/CC's: 800
Color: black
air switch valve
The VN800 has an air switch valve, which allows fresh air, from the air box, to get into exhaust port and burn the unburned gasses. Purpose of this valve is to meet EPA regulations. As a drowback, the temp of the exhausts is higher.
Does the Vaquero 1700 has a valve like the VN800 ? it can be eliminated ? Any pros and cons ?
marcelm is offline
post #2 of 3 (permalink) Old 11-15-2018, 02:37 PM
rozie's Avatar
Year/Make/Model: 2015 Vulcan Vaquero ABS SE
Displacement/CC's: 1700cc
Color: metalic carbon grey
air switch valve
I believe the 1700 vaquero does have the air switch valve, however, it is controled by the bikes ECU or computer and the only way I know of to turn it off is have the ECU reflashed by ivans performance. in addition to turning off the air valve he can do several things to make the bike run cooler, faster, smoother and get better mileage also.
check out his web site. ivansperformanceproducts.com/vn1700.htm
marcelm likes this.
2015 vaquero ABS SE {carbon grey}
12in. windshield
k&n air filter
freedom performance true duals
ivans ecu flash
kuryakin longhorn cruise pegs
sagebrush saddlebag chaps
oem aux lights
grasshoper driver backrest
black isso grips
chucksters risers
isso grip helmet locks
rozie is offline
post #3 of 3 (permalink) Old 11-15-2018, 03:33 PM
Peg
Peg's Avatar
Ivan's reflash is the preferred option to eliminate the switch valve. The only other solution that was widely used before Ivan came along, was to push a marble into the hose running from the 11 o'clock position at the back of the right side airbox. That helped to lessen the exhaust popping, but seldom stopped it entirely.
marcelm likes this.
Paul (Peg) Elliott
Peg is offline
Ignition Switch to Toggle Switch - Resistor? fieldschadl Vulcan 800 4 04-23-2018 10:04 AM
air switch bypass (reed valve) madmaths Vulcan 900 17 05-23-2013 05:12 AM
