Tire Change - Front Wheel Orientation - Kawasaki Vulcan Forum : Vulcan Forums
 2Likes
post #1 of 24 (permalink) Old 08-31-2018, 12:31 PM Thread Starter
Year/Make/Model: 2009 Vulcan Nomad 1700, 2009 Concours 1400, 1998 Honda VT1100
I am in the middle of my first front tire change on my 09 Nomad 1700 and I did not mark the wheel orientation when I removed the tire from the wheel. From the service manual I know that the spacers on each side of the wheel are the same, so does it matter which way I put the wheel back on? Obviously, I need to know that before I mount the new front tire to the wheel.
Thanks for the help.
Mike
MikesVN900C is offline
post #2 of 24 (permalink) Old 08-31-2018, 01:12 PM
VN750Guy**'s Avatar
Year/Make/Model: 2006
Displacement/CC's: 750
Color: Red/black
Are you referring to which way to install the wheel so that the direction of turn is the same?
If you know which spacers go on the left/right side of the forks, and if those spacers (installed that way) fit either side of the wheel, then no, it doesn't matter which direction of rotation the wheel is in.
If the spacers uniquely fit one side or the other of the wheel, then that would tell you which way to install the wheel.
Sounds to me like it doesn't matter on yours.
Chris Cochran
Retired USAF '74 to '95 AMMO
Engine guard with highway pegs
Luggage rack
GPS on RAM handlebar mount
MCCTs replaced ACCTs
Iridium plugs: DPR7EIX-9
Custom made seat (verrry comfortable)
LED turn signals with rear signals relocated
LED license plate holder
Hard mounted Viking saddlebags
Hard mounted fork tool bag (free from Viking)
LED running lights on custom light bar
National Cycles Low Boy Heavy Duty windshield
Home made lowers
VN750Guy** is offline
post #3 of 24 (permalink) Old 08-31-2018, 01:15 PM
VN750Guy**'s Avatar
Color: Red/black
On mine the speedometer/odometer is driven by the front wheel so my wheel will only fit one way if it is to operate the speedometer at all.
Chris Cochran
Luggage rack
Home made lowers
post #4 of 24 (permalink) Old 08-31-2018, 02:06 PM Thread Starter
Yes, that is correct. The spacers and the calipers are identical so I'm guessing it doesn't matter. On previous model 1600 Nomads I was told that the spacers were different so it did matter how the wheel was mounted. Apparently, on the 1700 Nomad they changed it so I'm looking for a confirmation. And I don't believe there is a speedo connector.
Mike
post #5 of 24 (permalink) Old 09-01-2018, 06:20 AM
CarGuy's Avatar
Year/Make/Model: 2014 Nomad ABS
Color: Black/White
Per the Nomad shop manual, the two front spacers are identical. They're mounted with the flange side out. There isn't a speedo connector. You'll need to mount the ABS sensor bracket on the left side.
Go for the ride!
2014 Kawasaki 1700 Nomad ABS
2008 Kawasaki 900 Classic LT (sold 2015 42k miles)
1975 Kawasaki KZ400 (sold ~1985)
1970 Suzuki TS250 Scrambler (stolen 1971)
1968 Bridgestone 200 MKII RS (sold 1970)
Patriot Guard Rider
USN 1971-75
CarGuy is offline
post #6 of 24 (permalink) Old 09-01-2018, 08:41 AM Thread Starter
My bike doesn't have ABS so I'm assuming that I can mount the tire anyway I want on the wheel and then the wheel can be reinstalled in the proper tire rotation. Thanks for the help. I think that answers it.
Mike
post #7 of 24 (permalink) Old 09-01-2018, 09:44 AM
CarGuy's Avatar
Color: Black/White
Mike
That's correct. The ABS doesn't make any difference to the spacers. Just mount either one on either side. Be sure to add a little hi-temp grease to the grease seal lips of the wheel bearings before inserting the spacers.
Go for the ride!
Patriot Guard Rider
USN 1971-75
CarGuy is offline
post #8 of 24 (permalink) Old 09-02-2018, 08:34 AM
texasnurse's Avatar
Year/Make/Model: (SOLD) Kawasaki Vulcan S [Harley-Davidson FLXTRS Road Glide Special]
Displacement/CC's: 107 (1746cc)
Color: Bonneville Salt Pearl
Mike
The Tire orientation arrow on the new rubber should face forward when rolling the wheel forward. as viewed from the left hand of the bike. Of course the direction of the wheel matters, unless you donít like front brakes.
Saddle up and feel the wind in your Helmet! ATGATT
texasnurse is offline
post #9 of 24 (permalink) Old 09-02-2018, 10:57 AM Thread Starter
Twin front brake calipers, non-ABS, no speedo cable and identical spacers left and right so again it appears how the tire is mounted to the wheel is not relevant? I understand that the tire does have a certain rotation. Doesn't anyone have an 09 Non-ABS Nomad that has changed the front tire by themselves and asked this same question.
Thank you for the reply.
Mike
post #10 of 24 (permalink) Old 09-02-2018, 12:03 PM
magicgrotto's Avatar
Year/Make/Model: 1995/ Kawasaki/vn1500
Displacement/CC's: 1470
Color: Black / Cream
Hi Mike hope your well
The tyre you have fitted is it a rear tyre or 1 specific for the front ???
IF it's a rear tyre you MUST fit the wheel SO the rotation arrow is facing the WRONG way
Hope this helps Steve
Although we may be miles apart , WE are FRIENDS that have never met !
magicgrotto is offline
Front wheel issue after tire change cruzin Vulcan 1500 2 03-09-2016 09:34 PM
Front Wheel Change JoshTodd Wheels and Tires 0 05-19-2015 08:43 AM
Battery Post Orientation Eddy Vulcan 500 2 01-11-2014 07:38 PM
97 EN500C LTD Battery orientation vulcan500_81005 Vulcan 500 6 01-02-2014 12:54 PM
front wheel change for vulcan coxy1955 Wheels and Tires 0 12-29-2010 04:41 AM
