2009 Nomad - Muffler Mounting Hole Alignment Problem - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 6 (permalink) Old 08-20-2018, 01:19 PM Thread Starter
Year/Make/Model: 2009 Kawasaki Vulcan 1700 Nomad
Color: Red & Gold
Hi Folks - I bought 2014 Vaquero stock mufflers from eBay. Before buying, I did some research and concluded that the eBay mufflers should fit my 2009 Nomad. Well, it looks like I was wrong. The right muffler went on with no problem. Unfortunately, the (2) left muffler threaded mounting holes are off by 3/8"., i.e., each muffler threaded mounting hole is 3/8" off of the respective motorcycle frame mount hole it's meant to go through. If the left muffler could be pulled toward the back of the bike 3/8" - all should fit. I've learned that getting the muffler pulled back 3/8" is easier said than done. My attempts to do so result in the left muffler being pulled 80% out of its gasket, which is unacceptable.
The left muffler has the dog-leg pipe that ties into the right-side exhaust. Except for exhaust head bolts, I've loosened just about every bolt that can be loosened to allow me to align the left muffler mounting holes - but no soap. At this point, I'm thinking that the 2014 left-side muffler mounting hole positions differ "by design" compared to the the 2009 models.
One thing I haven't done is loosen the exhaust pipes to heads attachments. There is the potential that this would allow me to finagle 3/8" on the left side muffler but then the exhaust attachments at the motor heads would be off 3/8" . BTW - 3/8" may not seem like much but when it's relative to fixed threaded holes - it is.
Another consideration would be to bend the left muffler's dog-legged pipe, which would be risky and could make matters worse.
Has anyone encountered difficulty aligning the mounting holes on the left muffler of a 1700 and if so, how bad was the misalignment and how did you overcome the problem?
Thanks for your feedback.
VinnyN is offline
post #2 of 6 (permalink) Old 08-20-2018, 01:53 PM
Peg
Peg's Avatar
The dog leg pipe on my Cobra aftermarket pipes needed to be "leaned on" just a little, to persuade it to fit properly. It doesn't take much bending to get it right.
Paul (Peg) Elliott
Peg is offline
post #3 of 6 (permalink) Old 08-20-2018, 03:18 PM Thread Starter
Color: Red & Gold
Thanks for the tip. By 'lean on' I assume you mean bend. How (what technique or equipment) did you use to bend the pipe? Thanks.
VinnyN is offline
post #4 of 6 (permalink) Old 08-21-2018, 12:16 AM
Peg
Peg's Avatar
You'll find it's not the pipe that bends, but the plate where the pipe is welded to the muffler. My mounts on the muffler were half an inch backwards of where they were supposed to be, so I simply upended the muffler so it was upright with the bent pipe resting on the ground (carpet on my garage floor)... and then applied a little weight (I have plenty of that)... I literally leaned on it.
Yours may need to be pulled the other way, but I'm sure you can figure something out so you don't scratch anything. Lie the muffler down on the ground and push the pipe by hand, or something like that? It won't require much movement at the join, to get it to fit further out, and that metal is very soft - it moves easily.
Paul (Peg) Elliott
Peg is offline
post #5 of 6 (permalink) Old 08-21-2018, 11:18 AM Thread Starter
Color: Red & Gold
Peg - I thank you for the info!
VinnyN is offline
post #6 of 6 (permalink) Old 08-28-2018, 08:04 AM
matt7even's Avatar
Yep my Cobra on the left side has alignment issues. Stripped the original bolt trying to get it to fit. Eventually I had to use industrial zip ties for the time being till I figure out a more permanent solution.
2009 1700 Nomad (Black)
OPT7 LED headlamp
Painted brake disks
Kawasaki light bar
Scootworks bar risers & engine chaps
RAM phone mount & drink holder
Kuryakyn speakers & AC outlet
National speedometer cowl
Wolo air horn
Oxford heated grips
Vaquero engine emblems
Mustang touring seat
Irons in the Fire rack
Kuryakyn Triple Play tail light
Cobra Tri-Oval exhaust
LED custom driving lights, accents, and turn signals
Goodyear Tripletred rear tire (205-16-60)
Ivans ECU flash
matt7even is offline
2009 Nomad Muffler vs 2014 Nomad Muffler VinnyN Vulcan 1700 4 07-31-2018 06:14 PM
2006 VN1600 Classic Muffler Bracket Alignment Issue. sashko1 Vulcan 1600 2 05-18-2015 08:49 AM
Hole Saw Exhaust Mod - 2011 Nomad Topangajack Vulcan 1700 4 10-30-2014 07:25 PM
Has Anyone Done A Carb Slide Mod Drilling Additional Hole Or Enlarging Stock Hole? 1994Vulcan88 Engine Work 24 07-14-2013 09:28 AM
2009 Kawasaki Vulcan 900 Gas tank & stock muffler jmess86 Bikes For Sale 0 01-30-2011 02:00 PM
