Vaquero saddle bag handles - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 2 (permalink) Old 08-10-2018, 01:55 PM Thread Starter
bigtiny115's Avatar
Year/Make/Model: 2017 Kawasaki vaquero 2001 Kawasaki Vulcan classic
Displacement/CC's: 1700 1500
Color: Cardinal candy red black red
How do you remove the saddle bag handles
bigtiny115 is offline
post #2 of 2 (permalink) Old 08-11-2018, 12:15 AM
Peg
Peg's Avatar
I just googled that question, and had a wealth of hits. Here's a quote from Jared over on the VBA. This is the process for his 1600 Nomad. Same bags & mechanism as your Vaq.
Originally Posted by Jared
Directly behind the handle is a small cover held with 5 or so small screws. Remove these screws and, with a small flat head screwdriver, pop that cover off. There are small tabs holding it on and while you're prying you'll see them and should be careful not to break them off.
Once that cover is off, you'll see the bar that the handle, two springs, and a few spacers all pivot on. Take a picture, so you can remember the order of everything. Remove the tension from the springs, then carefully remove the c-clip on one side and pull that pivot bar out. I was able to push it behind the large inner cover, but I have read where some had to drill a small hole to allow the bar enough space to pull all the way out.
Once the bar is out, the handle should be free. I'd immediately put everything back on the bar even while off the door, so that nothing gets lost.
And here's the thread it came from... Some other tips in there... Or just google it, like I did.
Paul (Peg) Elliott
Peg is offline
Hard bag handles Ozzy Vulcan 1500 1 12-29-2014 04:19 AM
WARNING: Loose bolts on Saddle bag hinges with Vaquero/Nomad style bags Hulk cowboy Vulcan 1700 4 10-30-2013 07:48 PM
Saddle bag chaps, tank bag and pcv IL Vaquero Wanted to buy or trade Items 0 02-04-2013 09:31 AM
Passenger grab handles? GearDoctor Vulcan 900 6 08-21-2010 08:39 PM
VN2K Now Handles Better!!! Woody General Vulcan Talk 4 11-19-2009 12:26 PM
