Gear indicater craziness - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
  • 1 Post By DrugerH
post #1 of 5 (permalink) Old 07-31-2018, 04:36 AM Thread Starter
SteveJB's Avatar
Displacement/CC's: 1700 cc
Color: Candy Cardinal Red
When I shift gears on my '17 Vaquero the indicater bounces around before settling on a gear. It has always settled on the correct gear, but I'm curious to know if this is common or an indication that something is amiss.
SteveJB is offline
post #2 of 5 (permalink) Old 07-31-2018, 06:25 AM
CarGuy's Avatar
Year/Make/Model: 2014 Nomad ABS
Color: Black/White
I've read quite a few posts about the indicator going "haywire". On my Nomad it started at around 30K miles. When shifting it'll either hesitate before showing the correct gear, or it will actually jump two gears (like from 2nd to 4th) before settling back to the correct gear. It doesn't do it every time, but enough to be noticed. It only takes a second or two to correct itself. I'd be interested in knowing a cause and fix, as well.
Go for the ride!
2014 Kawasaki 1700 Nomad ABS
2008 Kawasaki 900 Classic LT (sold 2015 42k miles)
1975 Kawasaki KZ400 (sold ~1985)
1970 Suzuki TS250 Scrambler (stolen 1971)
1968 Bridgestone 200 MKII RS (sold 1970)
Patriot Guard Rider
USN 1971-75
CarGuy is offline
post #3 of 5 (permalink) Old 08-01-2018, 08:34 AM
auwing1978's Avatar
Year/Make/Model: 2016 Voyager 1700 ABS
Color: Black-Silver
Send a message via AIM to auwing1978 Send a message via MSN to auwing1978
Mine has been doing same in the hot weather last week....2016 Voyager with 10K miles. Takes a few seconds sometimes to change to indicated gear. I have read that some folks see improvement when they change oil. Not sure if that has any bearing but I am about 5K miles on current oil/filter and will be changing out soon as I am taking an extended road trip. Will see if that settles it down.
When the going gets weird, the weird turn pro. HST
auwing1978 is offline
post #4 of 5 (permalink) Old 08-02-2018, 07:39 AM
DrugerH's Avatar
Year/Make/Model: 2009 Kawasaki Vulcan 1700 Classic LT
Color: Green/Beige
My bike does it too. I think it's the sensor because, for example, I can switch to 5th gear, but the bike will still show 4th gear. If I just touch the shifter with my heel, it will show 5th. I just do what I've done with previous bikes and just try to keep track of what gear I'm in.
Dan
auwing1978 likes this.
DrugerH is offline
post #5 of 5 (permalink) Old 08-02-2018, 05:11 PM
Peg
Peg's Avatar
Some have replaced the sensor to eliminate the problem, and then had it return. Most Vaq's / Voyagers seem to hunt like that for the right gear to indicate.
I find it quite endearing... as if my Voyager is a little bit like my wife is sometimes, and has a moments difficulty in making up her mind which gear to display. Little faults like that make the bike more likable, I find.
It only becomes a problem if the display starts showing lower gears while the cruise is set, and disengages it. That's never happened to me, so I can put up with it's little foible. Gear indicators are a modern and unnecessary luxury really, so near enough is good enough, for me.
Paul (Peg) Elliott
Peg is offline
Why Gear Indicator is not showing proper downshift gear thejunglerider General Vulcan Talk 2 11-01-2016 05:32 PM
New rider, bike shifts into gear, won't go, I shut off in gear and still roles?! Munchy2012 New Member Introductions 4 02-22-2016 04:15 PM
Bel Ray 85-140 Gear Saver GL-5 hypoid gear oil tim1 Oil and Lubrication 2 07-07-2012 08:55 AM
Transmission problem 3rd gear Roenoe17 Vulcan 1500 0 10-11-2008 02:19 PM
Question on Gear changing Jay General Vulcan Talk 7 08-26-2008 11:15 AM
