How much weight can the Voyager's top case/tour pack carry? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 9 (permalink) Old 07-30-2018, 11:05 AM Thread Starter
My Bandit's GIVI V46 top case will handle 21lbs., and between commuting with a loaded pack and running errands I bump up against that regularly. And since I'd like to continue putting everything into a single pack for my commutes, I'm hoping the Voyager's top case/tour pack can handle this much weight.
Toku57 is offline
post #2 of 9 (permalink) Old 07-30-2018, 09:39 PM
D-Dub's Avatar
Year/Make/Model: 2015 Voyager
I've carried more than 20 lbs on several occasions with no problems. On a 5-day 1500 mile trip we had all 3 bags packed to the gills plus a bag on the luggage rack that weighed at least 15 lbs and my wife was leaning against the thing the entire trip. Still no issues after 27k miles.
I can't imagine over loading the top case with normal riding gear items. Now if you're going to be hauling bowling balls you may have a problem
D-Dub is offline
post #3 of 9 (permalink) Old 07-30-2018, 10:22 PM
Ah believe the user manual says 10 lbs for trunk, 15 lbs for each saddlebag.
KawMan is offline
post #4 of 9 (permalink) Old 07-30-2018, 10:23 PM
Ah believe itís 10 lbs trunk 15 lbs per saddlebag.
KawMan is offline
post #5 of 9 (permalink) Old 07-31-2018, 01:09 PM
Peg
Peg's Avatar
I'd never take much notice of the manual's "butt covering" weight limit... Heaviest thing I've ever carried in my trunk is a car battery, but there have been numerous trips to the supermarket for boxes of beer & other weighty items. I've never heard of a trunk or bags being damaged through overloading, but there comes a point when the load distribution will either effect handling, find the limit of your suspension, or point your headlight too high for oncoming drivers.
When they're packed too tight, the bags & trunk will leak water inside in inclement weather anyway.
Paul (Peg) Elliott
Peg is offline
post #6 of 9 (permalink) Old 07-31-2018, 05:32 PM
for short trips and single rider, overload on the bag weights, yeah.
with two up and gear, the GVWR can easily be exceeded.
KawMan is offline
post #7 of 9 (permalink) Old 08-01-2018, 08:55 AM Thread Starter
Thanks all - very helpful info. I just weighed my backpack I put in my Givi loaded with the stuff I usually commute with, and it's actually a good bit under 21lbs., so I should be okay. As Peg pointed out, there comes a point where handling is compromised so I wouldn't want to put too much stuff back their anyway.
Toku57 is offline
post #8 of 9 (permalink) Old 08-02-2018, 06:41 AM
Bubba in TX's Avatar
I always have the trunk loaded and rack loaded when I go anywhere.
But I did have the rear hinge side of the trunk box lid crack one day with about a 3 inch crack when the wind whipped the lid open so hard it caused the side of the trunk to fold inward some when the safety cable stopped it and made a crack along the side of the lid hinge. Fixed with the ABS plexi fix. Cant tell it ever cracked and with added reinforcement pieces it will never do it again. Thinnest trunk material I ever had on any motorcycle I ever owned.
Bubba in TX
2011 Voyager "Betty Clunker"
Some people collect T-shirts
I actually ride
Voyager 1700 owners...
WRAP your pipes....
You will be glad you did...
U.S.A.F. Retired
Nye County Nevada
Motor Officer Retired
Blue Knights Texas 43
Bubba in TX is offline
post #9 of 9 (permalink) Old 08-02-2018, 05:18 PM
Peg
Peg's Avatar
I've wondered myself about whether I could rig up a second safety cable at the rear of the trunk to even up the load. But I couldn't think of an easy way to do it that wouldn't give me something else to make sure was tucked in when it closes, or which got in the way when loading it.
It certainly does flex alarmingly if I open it right up with something still strapped to the luggage rack though.
Paul (Peg) Elliott
Peg is offline
09 Voyager - remove tour pack Hox New Member Introductions 1 08-12-2017 07:50 AM
Hey! Working a basket case Hey! Working a basket case... Vn1500E Custom G-Pa's VN1500E Vulcan 1500 2 08-16-2016 09:21 AM
Voyager 1700 tour pack COE David New Member Introductions 1 10-24-2014 08:35 AM
Voyager XII tour pack accessories for Vulcan install Solodadof2 Bikes For Sale 1 08-27-2012 04:31 PM
Bike weight vs overall weight jeff72 Vulcan 1700 1 06-24-2012 10:38 PM
