Two switches ? - Kawasaki Vulcan Forum : Vulcan Forums
 2Likes
  • 2 Post By Bubba in TX
post #1 of 7 (permalink) Old 07-16-2018, 05:30 PM Thread Starter
Pilot747's Avatar
Two switches ?
On a '13 Voyager non abs, there are 2 switches activated by the rear brake peddle. One is located under the rear brake master cylinder the other is mounted on the inside on the master cylinder mount. And yes I know, that one is the brake light switch. The other, I have no idea and they don't seem to have to work in conjunction with each other. I'm sure there are many gussers here that will know. I've stared at the wiring diagram so long, now I'm like a chameleon.
2013 Kawasaki Vulcan 1700 Voyager
Pilot747 is offline
post #2 of 7 (permalink) Old 07-16-2018, 05:50 PM
JD Hog's Avatar
Year/Make/Model: 2015 Vulcan Voyager
Color: Metallic Carbon Gray/Metallic Spark Black
Could it be for a cruise control?
Jim Diebolt
2015 Vulcan 1700 Voyager ABS
"The Black Kaw"
JD Hog is offline
post #3 of 7 (permalink) Old 07-16-2018, 06:24 PM Thread Starter
Pilot747's Avatar
It's possible and I thought on that. My thinking is that it is disengaged by a brake light switch on the r/handle bar along with the switch on the clutch handle, so why wouldn't it use the brake light switch on the brake peddle instead of a separate switch. Hard to second guess the logic in that. I'll concentrate on that area in the wiring digram
Pilot747 is offline
post #4 of 7 (permalink) Old 07-16-2018, 06:34 PM Thread Starter
Pilot747's Avatar
After further investigation it appears that it is the cruise control cancel switch. Never mind all of the above.
Pilot747 is offline
post #5 of 7 (permalink) Old 07-17-2018, 01:09 PM
Demoliton Man's Avatar
Year/Make/Model: 2018 Indian Roadmaster
Displacement/CC's: 111 cui
Color: polished bronze over thunder black with silver pinstripe
The upper switch is brake light and the switch under the floorboard is to deactivate the cruise control.
In most times, the cruise control wont engage, there is a little stone/dirt or something else blocking the switch.
Cu,
Sven
"Democracy is two wolves and a lamb deciding what to have for dinner.
Liberty is a well-armed lamb." - Benjamin Franklin
Harley is cult, Victory is cool, but INDIAN is legend !
MY LIFE - MY RULES !
Demoliton Man is offline
post #6 of 7 (permalink) Old 08-02-2018, 06:47 AM
Bubba in TX's Avatar
Both brake switches, clutch switch will disengage the cruise. I disengage it just by slight back pressure on the clutch lever all the time.
Peg and Diggles like this.
Bubba in TX
2011 Voyager "Betty Clunker"
Some people collect T-shirts
I actually ride
Voyager 1700 owners...
WRAP your pipes....
You will be glad you did...
U.S.A.F. Retired
Nye County Nevada
Motor Officer Retired
Blue Knights Texas 43
Bubba in TX is offline
post #7 of 7 (permalink) Old 08-02-2018, 07:05 AM
T Gibbs's Avatar
Year/Make/Model: 2012 Vulcan Voyager
Color: Pearl White/ Beige
You can also disengage it by rolling the throttle off.
T Gibbs is offline
Handlebar switches needed woodie Vulcan 800 1 10-13-2013 09:57 PM
Vaquero Handlebar Switches barticus73 Vulcan 1700 5 09-08-2013 10:49 PM
Neutral Light and Sidestand Switches 2000VulcanClassicVN1500N1 New Member Introductions 3 07-12-2012 08:33 PM
Neutral Light and Sidestand Switches 2000VulcanClassicVN1500N1 Vulcan 1500 0 07-12-2012 03:49 PM
Signal Light Switches terryok New Riders 7 07-07-2010 07:49 PM
