Anti freeze - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 9 (permalink) Old 08-22-2012, 08:07 PM Thread Starter
dixie20j's Avatar
Anti freeze
So I got the anti freeze that said its for the dexatron GM vehicles. Can I use that in the bike?
Blue Knights AL III - V.P.
dixie20j is offline
post #2 of 9 (permalink) Old 08-22-2012, 09:04 PM
whoaru99's Avatar
I think it's supposed to be the plain old ethylene glycol stuff. I'm sure it gives the spec in the Owner's Manual.
whoaru99 is offline
post #3 of 9 (permalink) Old 08-22-2012, 10:00 PM
davidsheek's Avatar
If it doesn't say ethylene glycol I wouldn't use it. A lot of us use less than 50/50 to help it to run cooler.
davidsheek is offline
post #4 of 9 (permalink) Old 08-22-2012, 10:08 PM
Bubba in TX's Avatar
I use engine ice in all my water cooled scoots it is propylene glycol......
Bubba in TX
2011 Voyager "Betty Clunker"
Some people collect T-shirts
I actually ride
Voyager 1700 owners...
WRAP your pipes....
You will be glad you did...
U.S.A.F. Retired
Nye County Nevada
Motor Officer Retired
Blue Knights Texas 43
Bubba in TX is offline
post #5 of 9 (permalink) Old 08-23-2012, 01:07 AM
Color: Orange SE
+1. A lot of people don't realize that water actually cools better than any coolant or antifreeze. But, water also corrodes and freezes. Running more water and less antifreeze is a great way to keep the motor cool and happy in warmer climates. 50/50 is a 'one size fits all' grade. If you look at the back of some bottles of anti-freeze, it actually has a table for what percentage of anti-freeze you should be using in your climate!
You have to have some, of course. Even if you never ride when it's cold, it can freeze up and damage stuff sitting in a garage, or corrode your motor... but if you live in those hot southern climates, there's no need for half of that stuff to be antifreeze!
Romans5.8 is offline
post #6 of 9 (permalink) Old 08-23-2012, 10:35 AM
CRUISERDON's Avatar
The Biggest item of interest is that the coolant / antifreeze should be SILICATE FREE ! Silicate will eat up the water pump ceramic seal. If it says FLEET APPROOVED it should be ok, otherwise read, study, and verify !
I always run 50/50 mix, AND don't trust an old pressure cap ! They are too cheap to ignore !
CRUISER
DON RUSSELL
Aspire Machining
'97 VN1500 91 Cubes Of Custom CLASSIC
original owner
Vance & Hine 2to1
engine, forks, ignition & carb mod's
WebCam cam & rockers hard weld & grind
NEW TOP END, NO LOOKS ALL GO GO
Maxx intake manifold system & super G carb 44mm
CRUISERDON is offline
post #7 of 9 (permalink) Old 08-23-2012, 10:56 AM
wocka, wocka, wocka
Poncho Villa's Avatar
gm dex.. is propylene glycol (orange?) is better than ethylene (green). Specific heat value .87 vs .85, Water is 1.0, moves more heat per volume than additives but has narrower operating window. Anti-freeze/boil has wider operating window but moves less heat. Pure water would be best for the most heat removal but has all the bad attributes to go with it. so a concoction of mix is necessary.
Poncho Villa is offline
post #8 of 9 (permalink) Old 08-23-2012, 01:26 PM
PV thanks... I have never been around the GM orange antifreeze.... good to know.... might use it next time as I am sure it is cheaper than 25 bucks a quart...
Correct me if I am wrong but the silicates (which are basically sand particles) help clean and suspend other particulates if I remember correctly. Thus abrasive.... It is hell when you get old. 35 years ago I had to know what the particulate level was in boiler water treatment, and we used silicate.... expensive sand.... in different grit sizes...
Bubba in TX
I actually ride
WRAP your pipes....
U.S.A.F. Retired
Nye County Nevada
post #9 of 9 (permalink) Old 08-23-2012, 06:32 PM
wocka, wocka, wocka
Industrial and commercial closed loop cooling/heating system, those additives were probably desireable to help clean the heat exchanger tubes from scaling up. Those systems are heavier walled copper and steel systems that can handle the abbrasion. Our lite weight alum motors n radiators need a more gentle solution.
anti-freeze GregS Vulcan 900 10 02-08-2013 06:59 PM
anti-freeze leak frets21 Vulcan 900 12 11-15-2012 04:24 PM
anti freeze change out frets21 Vulcan 900 8 10-25-2012 11:02 AM
Which anti freeze to use? bearpawh Vulcan 900 8 04-05-2011 01:42 PM
Anti Freeze Problem gbutler11 Vulcan 900 3 11-22-2009 05:30 PM
