Anyone perform a brake-flush on an ABS model? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 10 (permalink) Old 08-22-2012, 01:20 PM Thread Starter
All,
My 2012 Voyager will be the third ABS-equipped bike I've owned. An earlier model BMW used a servo motor as part of the system and required a fairly complicated brake flush procedure. My second BMW's ABS was a straight forward technique, using a suction pump or the simpler method of using the brake lever and opening and closing the bleed valve.
Has anyone performed this on the the K-ACT system and if you have, does it require any special equipment that would keep me from doing this in my own garage with simple hand tools?
I know what you're gonna say... "buy a service manual."
I just got the bike and I'm still in the process of finding the best price on an electronic version of the 2012 manual.
Your experiences with this procedure are greatly appreciated.
Nerdybiker is offline
post #2 of 10 (permalink) Old 08-22-2012, 02:57 PM
davidsheek's Avatar
I did a brake-flush on mine about two months ago. I used the old-fashioned method of pumping the reservoir and bleeding it through a clear plastic tube through the bleeder valve. Being that the ABS models have more fluid is the reason I used a full can of DOT 4. It's no big deal, just flush it through.
But your bike is new, why are you consern about that now?
davidsheek is offline
post #3 of 10 (permalink) Old 08-22-2012, 04:57 PM Thread Starter
I had to order my Voyager and the dealer tells me it's been sitting in a crate for a year. Also, the dealer admittedly has avoided selling ABS bikes because they "don't sell" so their techs don't have much experience with ABS systems.
I do all the maintenance myself and I'm just planning ahead, so thank you for your post.
post #4 of 10 (permalink) Old 08-22-2012, 05:09 PM
Color: Orange SE
Originally Posted by Nerdybiker View Post
All,
The only place you can get a legal service manual is Kawasaki.com. They aren't too terribly expensive though, and are a great asset.
Romans5.8 is offline
post #5 of 10 (permalink) Old 08-22-2012, 05:13 PM
davidsheek's Avatar
If there's no symptoms of air in the brake lines I sure wouldn't do that until after a year or two of ridding. But hey, to each his own right?
I sent you a PM.
Looks like I'm outvoted lol What do I know after 62 years.
post #6 of 10 (permalink) Old 08-22-2012, 05:17 PM
RACNRAY's Avatar
In our experience with ABS equipped skoots the fluching and bleeding is the same as non-ABS skoots. We ALWAYS flush out the hydraulics at the 600 mile service check, the factory fluid is already well on it's way down the tube, and we always see either air or dark fluid.
Flush and bleed the hydraulics as soon as one can, it's a simple job yet will make an improvement in the operation and the lifespan of the components..
RACNRAY
"TRUE HAPPINESS IS IN THE HEART,NOT IN THE OUTSIDE FIXES!!"
WITH OVER 42 YEARS AS A MOTORCYCLE TECHNICIAN/HI-PO SHOP OWNER I AM A PURVEYOR OF FACT NOT FICTION!
"WE LIVE OUR LIVES IN CHAINS NEVER KNOWING WE HAD THE KEY"
RACNRAY is offline
post #7 of 10 (permalink) Old 08-22-2012, 05:31 PM
Color: Orange SE
I sent you a PM.
Brake fluid absorbs moisture from the air. RACNRAY and others have reported some nasty fluid right out of the crate. My wifes Honda Shadow is a leftover 2011 model, had 0 miles on it, but had a yellow tinge to the fluid in the master cylinder. Bled the brakes once I got it home and it was black and nasty at the bottom. The dealer had it sitting for a year, chances are they had it outside many a time on display, might have gotten rained on, who knows. The fluid breaks down over time, even if the bike isn't ridden.
FWIW, I do mine annually, bi-annually on the cars. Both vehicles have nasty looking fluid come out each time. Brake fluid is one of those often missed maintenance items. When I did mine on my bike, which is an '06 bought in '11 (did it when I bought it), the braking performance changed dramatically. But, failing to change the fluid won't cause your brakes to just stop working after a year or two, which is probably why most people don't do it. Get some miles and some years on it though, and it's time for a caliper rebuild or other nastiness. I'd rather just bleed the darn things!
post #8 of 10 (permalink) Old 08-22-2012, 05:41 PM
RACNRAY's Avatar
YEP...WHAT HE SAID!!
RACNRAY
RACNRAY is offline
post #9 of 10 (permalink) Old 08-23-2012, 07:24 AM Thread Starter
Thanks, RacnRay...
You're a true professional!!
post #10 of 10 (permalink) Old 01-19-2015, 11:35 AM
Need to revive this Brake bleed/flush thread for ABS Vulcans..
It is my understanding that under 13 MPH the linked brakes are turned off by computer. So, when flushing the brakes in garage, does the rear brake pedal only flush the rear? Then will the front brake lever flush both front calipers? Or just one? And if just one how would you flush the other?
Craig
Craigmri is offline
How often do you flush your brake fluid? Zzman General Vulcan Talk 26 05-03-2018 03:06 PM
Looking Vulcan S ABS, Vulcan S ABS Cafe Ger42 Vulcan 650 S 15 07-30-2017 01:10 PM
radiator flush engine flush Brewster_440 Vulcan 800 23 02-23-2017 09:12 PM
One Man brake fluid flush procedure. mdsimon80 Vulcan 900 0 11-22-2014 09:28 AM
Anyone going to San Diego for New Model Release Fyrzout Vulcan 1700 3 09-06-2013 11:28 PM
