error read out - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 10 (permalink) Old 08-21-2012, 08:40 PM Thread Starter
error read out
2010 nomad
soon afther taking off today , my display start showing err 18, and the red light was blinking,anyone knows what this means.
a wapstra is offline
post #2 of 10 (permalink) Old 08-21-2012, 08:59 PM
daddy mac's Avatar
I got these codes off the forum a while back, hope this helps.
Error codes for Voyager 1700
11 ETV Throttle position sensor malfunction, wiring open or short.
12 DFI Inlet air pressure sensor malfunction, wiring open or short.
13 DFI Inlet air temperature sensor malfunction, wiring open or short.
14 DFI Water temperature sensor malfunction, wiring open or short.
18 ETV Accelerator position sensor malfunction, wiring open or short.
21 DFI Crankshaft sensor malfunction, wiring open or short.
24 DFI Speed sensor malfunction, wiring open or short.
25 DFI Gear position switch malfunction, wiring open or short.
31 DFI Vehicle-down sensor malfunction, wiring open or short.
33 DFI Oxygen sensor inactivation, wiring open or short (Equipped Models).
46 DFI Fuel pump relay malfunction, relay is stuck.
49 ETV Return spring malfunction.
51 DFI Ignition coil #1 (Front Cylinder) malfunction, wiring open or short.
52 DFI Ignition coil #2 (Rear Cylinder) malfunction, wiring open or short.
56 DFI Radiator fan relay malfunction, wiring open or short.
58 ETV ETV actuator malfunction, wiring open or short.
64 DFI Air switching valve malfunction, wiring open or short.
67 DFI
Oxygen sensor heater malfunction, wiring open or short (Equipped
Models).
97 ETV Battery monitor voltage is low.
98 ETV ECU/ETV circuit malfunction, wiring open or short.
daddy mac is offline
post #3 of 10 (permalink) Old 08-22-2012, 06:33 AM
mine does the same error code 18. I shut it down and wait a few seconds and restart it. Goes away for a few days. Book says to replace ECU as last resort but not at 800.00 plus.When it restarts ,and I ride it, it runs the same as (no light) normal.Could be a quirk in the system.No symtons other than flashing light once every few days.I wonder if it has anything to do with the recall We all had.
larryg is offline
post #4 of 10 (permalink) Old 08-22-2012, 06:47 AM
whoaru99's Avatar
Yeah, I could see replacing the ECU as a last resort but surely the book gives some troubleshooting steps prior to that?
whoaru99 is offline
post #5 of 10 (permalink) Old 08-22-2012, 07:49 AM
My 2011 vaquero has done it twice now. The first time was back in June. I recycled the ignition switch and it went away. I took it to the dealer to check out several days later and they said they just cleaned the throttle valve sensor under the seat and reconnected it.
Then this morning starting to go to work, it did it again. I again cut the ignition off and on and it went away.
vulcan 06 is offline
post #6 of 10 (permalink) Old 09-27-2012, 08:35 AM
Bike had the error code 18 appear first thing this morning when i started my vaquero. I tuned the ignition off and back on. No problems. I had my 7500 mile service a few weeks ago and the tech said he ran a diagnostics check on the bike and the computer never even showed the code had appeared. He made a note in my record about it in case i have a problem later on.
Has anyone come up with a cause or solution for this anomaly?
post #7 of 10 (permalink) Old 09-27-2012, 01:36 PM
My 2009 Nomad has done the same thing. Last year when it kept doing that the dealer also put it on the computer. It showed nothing. They cleaned the throttle body and all was fine. It showed up again a couple weeks ago. Twice. I took it upon myself to clean the TB as it isn't hard. I also pulled the wires off of the APS and TPS and also the air sensor. I spray them all with electronic cleaner and haven't had it appear since then. Was that the cause??? I have no idea. All I know is my 2004 Nomad with FI never had problems that we are finding with these 1700's. I do know that we all seem to be having the same types of problems and no one can figure it out completely. I bet they think we are making this up. LOL
I have the service manual and the trouble shooting in it isn't very good in these cases except to check voltages and such. Oh I have done that to. What a pain that is. The voltages check out good too.
Bill
bpro215 is offline
post #8 of 10 (permalink) Old 10-10-2012, 11:40 AM
Bill
heres an update for mine. First off, can't say enough good for both Kawi. custimer service and my dealer. The customer service rep. (Nathan) was very receptive to my calling about error code 18 popping up. He said he would talk to the technical service guys there and call me back. Guess what, he did a couple of days later. Said they belived it's a combination of 2 things on my bike. One is to clean the throttle body and second is to check on a sticky throttle cable. Nathan also made a note of my calls for future reference.
My dealer was great about doing just what they suggested. In fact the dealer asked me back to the service area to show me exactly what they did and why and showed me their service manual recomendations. Showed me how to clean the TB as well.
On my bike there was a little build up in the TB. ( I strongly suspect its mostly due to the terrible gas (or should i say corn) we have around these days.) Also if you trace the throttle cable to the side of the TB (i'm not a mechanic as you can tell so bear with my less than technical references) it was dry around the spring mechanism so they lubed it up. Seems to have done the trick.
Bottom line. Sensor did what it was supposed to do. Minor cleaning and no worries.
post #9 of 10 (permalink) Old 10-10-2012, 08:41 PM
twowheeladdict's Avatar
A little seafoam goes a long way in keeping the fuel system clean.
twowheeladdict is offline
post #10 of 10 (permalink) Old 10-11-2012, 03:45 PM
+1 on that.
Vulcan Classic 1500fi flash error codes frogman957 Vulcan 1500 7 06-17-2017 11:06 PM
Error 21 read out Salesar90 Vulcan 1700 2 01-28-2016 10:20 AM
Front end wobble & LED read-out..... Law Dawg Vulcan 1700 5 09-25-2013 06:36 PM
Speedometer error Coolpig59 Vulcan 2000 3 07-12-2010 06:48 AM
