fi 2000 r - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 3 (permalink) Old 08-21-2012, 05:59 PM Thread Starter
fi 2000 r
2011 voyager v&h slip ons no air kit. what pot settings has anyone got that works best? cobra says wont help popping but have seen some say it does. any ideas already put on new gaskets from motor back
oldrampy is offline
post #2 of 3 (permalink) Old 08-21-2012, 08:18 PM
captram1's Avatar
Thumbs up
I'm riding a 2010 Nomad. I added a Thunder Air Kit (this is a must do), removed outer and inner baffles on OEM mufflers and added the Cobra FI2000R. After the modifications that I made the bike ran great. No more lean surge on acceleration and very little popping on deceleration. I decided to take my ride in to my local race shop and had it dynoed and mapped. I was running the stock pot setings from Cobra before putting it on the dyno. Basically I was running lean on the low speed pot, rich on the mid range and high speed pots. After the tech completed the mapping the results were very impressive. I went from 72.44 HP to 79.13 HP at the rear wheel. Torque went from 89.22 lb.ft. to 92.27 lb.ft. I just ran my third tank of gas through the bike and my mileage went from an average of 32.4 mpg to 36+. The bike is as smooth as silk through out the power band now. I don't think that a random adjustment of the pots will do the machine justice. I feel it should be set up on the dyno. If you want to PM me I'll check my pot settings tomorrow and I'll send them to you...no problemo
2010 1700 Nomad
Cobra FI2000R
Thunder Air Kit (51010)
Kawi Light Bar
Front Fender Trim Rail
Saddlebag Trim Rails
Grasshopper Driver Back Rest
Cobra License Plate Frame (Vulcan)
Flags and Mounts by Rumbling Pride
Kuryakyn Long Horns
Headlight/Spotlight Visors
Kuryakyn ISO Grips w/RACNRAY MOD
AMSOIL 10W40
Hot Leathers Clutch&Brake leathers 17"
Nation Cycle Chrome Rear Fender Trim
captram1 is offline
post #3 of 3 (permalink) Old 08-21-2012, 08:37 PM
Shipped settings are 4.5, 4.5, 0. The first pot is the one you will need to focus on. I would start by riding the bike at stock settings and then check the plugs. Adjust in half increments. The last pot is only adjusted when an air kit (not just replacement air filter) is bolted on. Plugging the fresh air hose coming in the right side air box will have some effect on decreasing popping also. I would use the shipped settings as a starting point rather than trying to copy someone else's settings. My settings are 4.9 (just a hair under 5.0)4.5, 3.5 My mods, Cobra slip ons, thunder air kit 51010, air temp sensor relocated to neck, cobra fi2000r.
2011 Black Vaquero
V&H Slips, Thunder Stock Air, Cobra Fi2000r
1700Classic is offline
2000 1500 fi and the 2002 1500 fi engine rwjohnson24 Vulcan 1500 0 05-14-2017 06:12 PM
Considering Nomad 1500 front end for 1500 classic Fi (year 2000) juha_teuvonnen General Vulcan Talk 0 05-27-2010 04:41 PM
Head Gasket Leak - I think - 2000 Classic 1500 FI exsailor Vulcan 1500 0 05-09-2010 04:02 PM
Fuel Mileage 2000 Nomad FI elbee1958 Vulcan 1500 0 04-09-2009 12:29 PM
Vulcan 1500cc Fi 2000 - best bike I've owned GiveThanks New Member Introductions 4 02-14-2009 07:07 PM
