Battery - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 7 (permalink) Old 05-20-2018, 12:13 PM Thread Starter
revrider's Avatar
Year/Make/Model: 2010 NOMAD
Color: Black/titanium
Battery
Battery tested today,going bad,question is what are you guys putting in your 1700s
went to 3 part stores,found 2 that might work but would rather have correct one,will order off line,thanks
revrider is offline
post #2 of 7 (permalink) Old 05-20-2018, 12:59 PM
Sabre-t's Avatar
Color: Red/Black
An AGM battery with a format number (not necessarily the model number) ending in "something"-BS (for example a 20CH-BS format Xtreme brand AGM battery from Batteries Plus or Batteries + Bulbs). Typically, the number before the dash gets higher as the cold cranking amps (CCA) go up as well at the amp hours (Ah) total capacity. Just go to a battery place and have them do a cross reference for the correct battery for your bike. Make sure the battery is not more than 6.45" high.
I think a 16-BS is typically about 230 CCA while a 20-BS would be about 270 CCA, but some mfg may not adhere to that.
Installed:
Longer Kickstand
Dobeck EJK 3.0
Lucky Mirror Extenders
Wiring for Trailer
Ray's Throttle Mod
Things to do:
LET'S RIDE
Sabre-t is offline
post #3 of 7 (permalink) Old 05-20-2018, 01:51 PM Thread Starter
revrider's Avatar
Thanks sabre,yea long story short,hd dealer put a new one in since he could not find the one for it when I bought it,it has a hd batt w brass L brackets for the 2 top post terminals,I guess what I am asking is for a specific battery for it,this one has 225cc at 12a,rather delete the brass L ,terminal ends r like a u clip,not sure this is stock but looks like it,guy said cut tabs off terminals,dont want to,saw one on line only has 200cc but will fit,prob making too much of this
revrider is offline
post #4 of 7 (permalink) Old 05-21-2018, 08:43 AM
Year/Make/Model: 2011 Vulcan Voyager
Color: Blue/Silver
I use a Yuasa ytx20ch-bs.
Bluemeanie is offline
post #5 of 7 (permalink) Old 05-21-2018, 12:27 PM
Reptilicus's Avatar
Year/Make/Model: 2008 Mean Streak
Displacement/CC's: 1600
Color: Candy Fire Red
I'm wondering if some of the dimensions of batteries have changed for the same ratings.
I decided to replace mine since as near as I could tell it was the original. The same model number was noticeably larger. It fit in the box but the module that is supposed to be next to it would not go back in.
So I ended up with a slightly smaller battery, 200 CCA versus the 270 that came out. Starts much quicker but longevity remains to be seen.
Reptilicus is online now
post #6 of 7 (permalink) Old 05-21-2018, 07:17 PM Thread Starter
revrider's Avatar
Thanks for the replies,Ended up ordering a ytx16ch-bs,230cc,should b ok,half the price of the parts store,will know when it gets here
revrider is offline
post #7 of 7 (permalink) Old 05-24-2018, 06:53 PM Thread Starter
revrider's Avatar
Battery came in,charged it for an hour,Fit perfectly,definitely noticed the difference,will c how it holds up,18 mo warranty
revrider is offline
is my battery too weak ? indicated from Kury battery gauge evodog Vulcan 900 17 09-16-2013 10:55 AM
Battery Tender Questions jivolella General Vulcan Talk 18 08-09-2009 05:45 PM
Battery Chargers crooksie General Vulcan Talk 10 03-04-2009 11:06 AM
