Belt Alignment - Kawasaki Vulcan Forum : Vulcan Forums
 1Likes
  • 1 Post By stessel
LinkBack Thread Tools
Old 05-05-2018, 02:41 PM Thread Starter
Year/Make/Model: 2015 Kawasaki Voyager
Color: Charcole Gray
Belt Alignment
I have a 2015 Voyager. I bought it new 2 years ago, so this is my third summer for the bike. Ever since Iíve had it, itís been making a noise from the belt every time Iíve slowed down. Itís been back to the dealer twice and they say there is nothing wrong with it. It now has 10,000 km on it. I just did the seasonal maintenance on it and I noticed the belt is not centred in the rear pulley. Might this cause the noise ? I do not have a belt tension gauge, so I will have to bring it to a shop to be adjusted, but donít want to throw away money if there is nothing wrong. Here is a picture. What do you guys think? I havenít seen a picture of another one so I have nothing to compare it to. Thanks. Sorry the picture loaded sideways.
sailorman3 is offline
Old 05-05-2018, 03:07 PM
stessel's Avatar
Year/Make/Model: 2016 Kawasaki Voyager
Color: MetalicBlackk/Silver
Hey,
Yeah that is about the way my 2016 looks on the pulley it would take some serious fine tuning to get to where the belt will keep an even gap on both sides of the pulley. Take your sadle bags off and check to make sure your axle alignment marks are even on both sides. If you wanted you can find those spring scales pretty cheap on line to check your belt deflection you just apply 10lbs of pressure on the belt at the little window on the belt guard and I think the belt should deflect between the 2nd and 3rd lines in the window. The owners manual tells you how to check it. If you do need to adjust the belt it is not hard if have the tools and some mechanical skill. If not it is still worth having the spring scale so you don't pay the motorcycle shop to tell you it is good.
stessel is offline
Old 05-05-2018, 03:22 PM
Year/Make/Model: 2008 V900 Custom
Displacement/CC's: 900
Are you sure the noise is coming from the belt?
PERFORMANCE:
ECU reprogrammed by Ivan
Cobra Speedster Pipes
Barons BAK intake
Progressive springs in the forks.
COMFORT:
Kuryakn ISO Grips
Mustang Studded Wide Touring Seat with Driver Backrest
OEM Passenger Backrest.
MISC:
Added Grease fittings to Stem, Tie Rod, and Swingarm.
Cobra Crash Bar
Red LED lights by PO
170/80 Commander II in the rear
westcoastkevin is online now
Old 05-05-2018, 03:37 PM
JD Hog's Avatar
Year/Make/Model: 2015 Vulcan Voyager
Color: Metallic Carbon Gray/Metallic Spark Black
Most likely the belt is too tight. The factory specs are what makes it noisy at slower speeds. Loosen it up until the noise goes away. My bike was in for the 15,000 mile service and they tightened the belt to the specs and my noise came back. I backed of on the tension an all is good again. The service techs have to use Kawasaki's specs so you will need to do this yourself or find an independent shop that will help you.
Jim Diebolt
2015 Vulcan 1700 Voyager ABS
"The Black Kaw"
JD Hog is offline
Old 05-05-2018, 03:39 PM Thread Starter
Pretty sure. Itís a whomp, whomp ,whomp ( for lack of a better word) noise at slow speeds. I donít think it could be anything else.
Old 05-06-2018, 08:46 AM
Biker Dash's Avatar
Year/Make/Model: 2011 Kawasaki Vulcan Nomad
Color: Metallic blue/silver
Send a message via Skype™ to Biker Dash
My belt looks just like that, and it makes the same noises at low speed.
Yes, making it looser will quiet the noise, but then it feels like there is excessive lash, at least to me, it feels that way. A little belt noise for smoother operation is an acceptable trade, in my personal opinion.
2011 1700 Nomad -- "Princess Celestia"
2003 1500 Dodge Ram Quad Cab 5.9 "Nightmare Moon"
Biker Dash is offline
Old 05-08-2018, 09:03 AM
stessel's Avatar
Hey,
If you make it too loose the noise may go away, but not only will you get that lash when you take off it will also wear your belt out sooner and cause wear on the drive pulleys
silverpugj likes this.
stessel is offline
Proper Belt Alignment/Adjustment ashtavakra Vulcan 900 9 10-16-2017 04:17 PM
Belt deflection and wheel alignment CarGuy Vulcan 1700 2 04-25-2016 07:10 PM
Belt alignment issue obeah08 Vulcan 900 12 07-28-2013 02:18 AM
Belt alignment question Rtsitler Vulcan 900 28 05-29-2012 10:40 AM
Belt tension - axle alignment IsAnOzzie Vulcan 1700 16 05-29-2012 03:20 AM
