Tire pressure - Kawasaki Vulcan Forum : Vulcan Forums
 3Likes
  • 1 Post By stessel
  • 1 Post By btom
  • 1 Post By stessel
post #1 of 8 (permalink) Old 04-21-2018, 06:18 PM Thread Starter
Year/Make/Model: 2017 Vulcan Voyager
Color: Blk/gray
Tire pressure
I own a 2017 Vulcan 1700 Voyager and I just replaced my stock tires with the Bridgestone Exedra Max Tires. The tire reads 41psi cold on both, is that the correct pressure??
Walt55k is offline
post #2 of 8 (permalink) Old 04-21-2018, 07:45 PM
I have the same set up and run 40 cold
bullcrapallday is offline
post #3 of 8 (permalink) Old 04-21-2018, 08:08 PM
stessel's Avatar
Year/Make/Model: 2016 Kawasaki Voyager
Color: MetalicBlackk/Silver
Hey,
I have Michelin commander II's on my 2016 Voyager and run 42 cold in the back and 36 cold in the front. with 25 psi in the shocks gives me a comfortable ride. the lower pressure in the front helps absorb some of the road feel and still gives good control in turns the 28 psi the manual says to use is just to soft for me. The higher pressure in the back still gives a comfortable ride with good grip and helps with tire wear
But that is just me. You have to play with it and find what is right for you
Walt55k likes this.
stessel is offline
post #4 of 8 (permalink) Old 04-22-2018, 09:47 AM Thread Starter
Color: Blk/gray
What size Commander II are you running in the back? I couldn't find a 170/70x16 Commander II
Walt55k is offline
post #5 of 8 (permalink) Old 04-22-2018, 11:51 AM
btom's Avatar
Year/Make/Model: '05
Displacement/CC's: 800
lower tire pressure = more grip due to increase in contact patch with road, tire runs warmer, more tire wear thus less tire life
higher tire pressure = tire runs cooler, less contact patch with road thus less grip, more tire life
choose your option, you want more grip or less grip,, less tire life or more tire life
Walt55k likes this.
btom is offline
post #6 of 8 (permalink) Old 04-22-2018, 03:45 PM
stessel's Avatar
Hey, Wait55k
you have to use a 180/65/16 instead of the stock 170/70/16 in the Commander II it is a little wider but the height of the side wall comes out to be the same at least it does not affect the speedometer or seat height. Front tire they have in 130/90/16 size I highly recommend them while I only have about 4k on them they ride great and also holding up very well as far as wear they still look like I just put them on people say they have gotten anywhere between 14-20k miles on them depending on your riding style.
I also tried glass balancing beads in them instead of having them balanced with external weights and so far very happy with cruising speeds up to 80 mph
Walt55k likes this.
stessel is offline
post #7 of 8 (permalink) Old 04-22-2018, 04:29 PM Thread Starter
Color: Blk/gray
Commander II
Thx for the info, I really like the Commander II tires had them on my other ride. Just wasn't sure I could put the bigger tire on the back. Thanks a lot.
Walt55k is offline
post #8 of 8 (permalink) Old 04-22-2018, 08:08 PM
Sabre-t's Avatar
Color: Red/Black
Just for the record, the pressure on the side of the tire is the maximum cold pressure, not a recommended pressure.
Installed:
Longer Kickstand
Dobeck EJK 3.0
Lucky Mirror Extenders
Wiring for Trailer
Ray's Throttle Mod
Things to do:
LET'S RIDE
Sabre-t is offline
900 Custom Tire Pressure ???? ScottyJ Vulcan 900 13 09-25-2014 11:53 AM
Tire pressure for VN 1600 Classic RevKev Vulcan 1600 7 05-11-2013 12:44 AM
Thinking of Designing an Oil Pressure adapter for oil pressure and temp gauge bikeman2011 Vulcan 900 1 04-20-2011 05:01 PM
Ideal Tire Pressure cottam Vulcan 1500 1 06-18-2009 01:38 PM
Scraping Pipes, Synthetic Oil, Tire Pressure CruisingEagle Vulcan 2000 2 07-13-2008 07:20 AM
