FI Controllers - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 24 (permalink) Old 07-27-2012, 11:45 AM Thread Starter
Color: Burgundy and Black
FI Controllers
I have a 2010 Voyager with V&H slip ons, Thunder Air Kit with the original cover, Cobra FI 2000 and Ray's throttle mod on a set Kuryakin ISO Grips. I am considering switching to a PCV this winter and was wondering do I need the auto tune option. I was searching the web today looking at the PCV's and found a Dynatek 3000. Does anyone have experience with the Dynatek 3000? How does it compare to the PCV? I know that there has ben threads on the PCV, but I have never found one for the Dynatek 3000. Thanks for all responses. BTW, I think Ray's throttle mod has been the best mod yet. I wish I had done this as my first mod.
Big Reyn is offline
post #2 of 24 (permalink) Old 07-27-2012, 04:17 PM
Combat72's Avatar
Big Reyn.
I just installed a PCV with Autotune. There are numerous maps that people on here are very generously willing to share. I decided to install the Autotune so the bike will constantly adjust to conditions based on what the O2 sensor is reading. I started my adjustments at 20% and have been reducing that percentage as it fine tunes. If I make changes, like adding a big air kit, the Autotune should be able to adjust my base map. That's what I'm hoping anyway.
Frank
2010 Voyager/ Metallic Diablo Black/Metallic Imperial Red
1972 Norton Commando - Yellow
PCV(Fuel & Ignition) With Autotune
Gear Advance Fuel & Ignition Mapping
Cobra 4' Scalloped Tip Slip-Ons
Wrapped Exhaust Manifold
Kuryakyn ISO Grips with RacnRay Mod
Kuryakyn Bar End weights
Ultimate Mid-Rider
Polk Audio DB521 speakers
K&N Air Filter
Rear Speakers
Mirror Risers
iPod Adapter
Combat72 is offline
post #3 of 24 (permalink) Old 07-27-2012, 11:44 PM
davidsheek's Avatar
Well first of all the Dynatech 3000 is for carbureted bikes only, so scratch that of your list right now.
The PCV comes in three ways. First is the PCV fuel only, then you have a choice of PCV with ignition, which means you can change the ignition timing as well as fuel maps. Then the last PCV with autotune, and like Frank said you can make fine adjustments from what the autotune is telling you. The PCV by itself runs under $300 and like Frank said I would send you the map that I'm using and I'm sure he would too. Or you can pay more and get the autotune which doesn't mean it automatically tunes. You have to make the adjustments with a laptop and you have to weld a O2 sensor in your pipe. There are pictures in this forum. So think it over carefully before you decide.
davidsheek is offline
post #4 of 24 (permalink) Old 07-28-2012, 07:36 AM Thread Starter
Davidsheek, which version are you using? Do you think the autotune is worth the additional money? I'm asking questions so I can make the most informed decision. Thanks
Sent from my SCH-I510 using Motorcycle.com Free App
Big Reyn is offline
post #5 of 24 (permalink) Old 07-28-2012, 09:28 AM
davidsheek's Avatar
In 2009 I started out with the PCV and liked it just fine. It did everything it was supposed to do. Just recently I decided to sell that one and get the PCV with ignition because of what Racnray said and the fact that I always felt that these bikes could use some help in that department. But keep in mind advancing the ignition can be very dangerous to your engine unless you know what you're doing.
Personally I would not get the autotune because good maps are available here on the forum. But if money is not a problem then I think you cannot go wrong.
post #6 of 24 (permalink) Old 07-28-2012, 10:15 AM
Combat72's Avatar
David Sheek,
You said the Autotune doesn't mean it automatically tunes. My understanding is that if you have the Autotune installed it adjusts while you ride based off the maps and the percentages you have set. Am I wrong?
Frank
Ultimate Mid-Rider
K&N Air Filter
Rear Speakers
Mirror Risers
iPod Adapter
Combat72 is offline
post #7 of 24 (permalink) Old 07-28-2012, 10:42 AM
whoaru99's Avatar
Originally Posted by Combat72 View Post
David Sheek,
Frank
That's my understanding too. You can put limit(s) to how much you allow Autotune to trim up/down from the base map, but trim within those limits it does, on the fly, afaik. If Autotune doesn't "auto tune" then what's the point?
I have seen a few people splitting the cost of an Autotune setup, then each person uses it for a while to get things tweaked in, then passes it on to one of the others.
whoaru99 is offline
post #8 of 24 (permalink) Old 07-28-2012, 10:55 AM
davidsheek's Avatar
I'm just going by what I read in the past. I could be wrong but I thought you had to accept the suggested map from the autotune. Now I can find out for sure really easy with a little reading on my part if you like. Maybe someone that has had an autotune for a good while will read this and give us their thoughts.
post #9 of 24 (permalink) Old 07-28-2012, 11:26 AM
whoaru99's Avatar
I think this is a very interesting topic. Way I read it is that you only have to save in two cases.
1. If you want to write the Autotune values to the base map/different map, or
2. if the Autotune values are greater than 20% change and more is required.
In the case of #2, say for extreme example that Autotune determines a 50% change to some value(s) is necessary. It can only do 20% max at a time. So, you'd have to accept the first 20%, save that, then allow it to do another 20% to that map, save that, then either save the final 10% or just allow it to Autotune around that point. Could be wrong, but that's my interpretation of it.
EDIT: The later part about the max trim isn't quite right. The system will allow only +/- 20% max trim on the fly/by itself, but apparently you can manually accept/write larger values from trim table to a fuel map/table.
whoaru99 is offline
post #10 of 24 (permalink) Old 07-28-2012, 11:53 AM
Combat72's Avatar
That's what I was thinking. I took Power Commanders Map for VV with Vance and Hines Slip-Ons and Stock air filter. My initial adjustments were 20% for both lean and rich. I would ride, accept trims and then repeat the process. Once I did that several times I started lowering my trim percentage. Have it now at 10% rich, 5% lean. My understanding is the Autotune will automatically adjust on the fly based on the map you have saved and the trim percentages entered.
Frank
Ultimate Mid-Rider
K&N Air Filter
Rear Speakers
Mirror Risers
iPod Adapter
Combat72 is offline
2000 1500 fi and the 2002 1500 fi engine rwjohnson24 Vulcan 1500 0 05-14-2017 06:12 PM
Best After Market Exhaust For Vulcan1500 With Fi? bevlaur Engine Work 30 03-07-2016 11:26 PM
Fuel (EFI) controllers slaponte Vulcan 1600 10 08-13-2011 10:02 AM
Windshield Problem - VN 1500 Fi lancec General Vulcan Talk 0 07-21-2008 03:48 PM
