overdrive gear - Kawasaki Vulcan Forum : Vulcan Forums
 6Likes
post #1 of 11 (permalink) Old 03-05-2018, 12:25 PM Thread Starter
marcelm's Avatar
Year/Make/Model: 1995/Kawasaki/VN800A
Displacement/CC's: 800
Color: black
overdrive gear
Hi,
I read from Vaquero specs "6 gear with overdrive". What does this mean exactly ?
Is this a separate device\gear case ?
How to "activate" this overdrive gear ?
Or is it just the 6th gear but with very high rear ratio ?
Marcel
marcelm is offline
post #2 of 11 (permalink) Old 03-05-2018, 12:42 PM
rick's Avatar
I do believe 5th and 6th are overdrive ratios. Nothing special to do, just shift as normal, the ratios are just over drive gear, meaning the output shaft turns faster than the input in these gears.
RACNRAY likes this.
2005 800 classic
2012 Voyager ABS
rick is offline
post #3 of 11 (permalink) Old 03-05-2018, 12:47 PM Thread Starter
marcelm's Avatar
Color: black
Clear for me.
Thank you.
marcelm is offline
post #4 of 11 (permalink) Old 03-05-2018, 01:07 PM
dlars's Avatar
Originally Posted by marcelm View Post
Hi,
Marcel
.....or just watch what your RPM's do when you shift up into the top two gears, they drop significantly in 6th which is great for relaxed cruising on fairly flat roads
marcelm and RACNRAY like this.
2012 Kawasaki Voyager
Dynojet PCV Fuel Processor
Kuryakyn Offset Highway Pegs
RacnRay's Throttle Grip
iPod Connector
Manual Fan Switch
dlars is offline
post #5 of 11 (permalink) Old 03-05-2018, 01:56 PM
DaPreacha's Avatar
Year/Make/Model: 2012 Kawasaki Nomad
Color: Red/silver
I have the Nomad with overdrive and I don't even use 6th gear until I am going 70+. Lots of hills where I am in NC. I love the 6th gear though on the interstates.
marcelm likes this.
DaPreacha is offline
post #6 of 11 (permalink) Old 03-05-2018, 10:05 PM
stessel's Avatar
Year/Make/Model: 2016 Kawasaki Voyager
Color: MetalicBlackk/Silver
Hey, Yep 6th is just a higher gear ratio for cruising highway speeds
marcelm likes this.
stessel is offline
post #7 of 11 (permalink) Old 03-09-2018, 09:58 AM
auwing1978's Avatar
Year/Make/Model: 2016 Voyager 1700 ABS
Color: Black-Silver
Send a message via AIM to auwing1978 Send a message via MSN to auwing1978
I used my 6th gear more often and at lower RPM after I had Ivan reflash my ECU. I am able to use 6th more efficiently at RPM's down to 1800 on the highway.
When the going gets weird, the weird turn pro. HST
auwing1978 is offline
post #8 of 11 (permalink) Old 03-09-2018, 10:16 AM
RACNRAY's Avatar
I see all over the erroneous use of the phrase "higher gear ratio" when referring to "higher gears" such as 6th gear. I even see this in m/c magazines!
"Higher gears" (like 6th gear) are in fact "lower" gear ratios NUMERICALLY. Take for instance the 1700's have a 2.933 to 1 ratio for first gear (thus the correct term of high gear ratio applies here), and 6th gear is a .806 to 1, thus the correct term is low gear ratio. "Overdrive" ratios are numerically less than a 1 to 1 ratio.
As has been stated 5th is also an overdrive, 5th being .967 to 1
RACNRAY
"TRUE HAPPINESS IS IN THE HEART,NOT IN THE OUTSIDE FIXES!!"
WITH OVER 42 YEARS AS A MOTORCYCLE TECHNICIAN/HI-PO SHOP OWNER I AM A PURVEYOR OF FACT NOT FICTION!
"WE LIVE OUR LIVES IN CHAINS NEVER KNOWING WE HAD THE KEY"
RACNRAY is offline
post #9 of 11 (permalink) Old 03-09-2018, 11:03 AM
stessel's Avatar
Hey, Yeah you are right but you are thinking about it backwards and that is why it is considered a higher gear ratio. So it the input or the drive pulley has to turn 2.933 times to turn the output pulley or the rear tire 1 time so by the time you are in 6th gear and the input is now turning 0.806 turns to turn the output rear tire 1 time it is the output that is turning at a higher ratio or higher gear.
stessel is offline
post #10 of 11 (permalink) Old 03-09-2018, 11:31 AM
stessel's Avatar
Ok I explained that wrong,
But same principle the drive pulley and the rear tire pulley ratio is fixed it is the ratio between the transmission gear and the drive pulley that changes.
Same thing though in first gear the gear turns 2.933 times to turn the drive pulley 1 turn. In 6th gear the gear turns 0.806 times to turn the drive pulley 1 time. So if 6th gear turned the 2.933 times the same as first gear the drive pulley would turn 3.63 times thus the output is a higher ratio than the input
I think that's right
stessel is offline
Scootworks Front Overdrive Pulley MrClean Vulcan 900 207 04-17-2011 12:12 AM
Overdrive Pulley Silver Shadow Vulcan 900 2 06-07-2010 01:03 PM
now a 4 speed w/an overdrive Poncho Villa Vulcan 2000 5 06-06-2010 05:18 PM
Scootworks Overdrive Gear papawhisky Vulcan 900 7 05-30-2010 09:30 PM
Best mod ever = overdrive pully BIGREDDON Vulcan 900 6 02-14-2009 08:42 PM
