Vaquero 21" wheel wobble - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 7 (permalink) Old 07-26-2012, 12:29 AM Thread Starter
BOTM Winner, June 2013
Hey I purchased the 21" wheel for the Vaquero from Roaring Toyz. I notice a lot of wheel wobble at hwy speeds of over 70mph. I emailed Robert at roaring toyz, and he said it sounds like the tire needs to be re-balanced. I have the counter balanced beads in the front wheel, I have used these before and never had a problem. I need to know if anyone else has this set up, and if so, did you have any issues like this, and if so how did you correct it. Thanks.
Law369 is offline
post #2 of 7 (permalink) Old 07-26-2012, 08:50 AM
Vaqabond's Avatar
Quick checks would be tire pressure, have the balance re-checked and look at the brakes to see if there's any interference that might not be noticible until higher speeds.
Here's another thread https://www.vulcanforums.com/forums/s...ad.php?t=28178 discussing the 21" upgrade. Maybe throw your issue on there as well.
Keep us posted with what you find.
2011 Vaquero in Red
Mustang Wide Touring w/Drivers Backrest
KQR Passenger Backrest w/Mustang Pad
Passenger Floorboards
and on....
and on...
and on..
Vaqabond is offline
post #3 of 7 (permalink) Old 07-27-2012, 04:43 PM
Cstmcycle's Avatar
LAW369 the black bike in the other threads front tire was computer balanced before it was installed.
Cstmcycle is offline
post #4 of 7 (permalink) Old 08-18-2012, 11:42 AM
Cool Wheel wobble no problem
I have a bout 1000 miles on my 21" front wheel and have not noticed any problem at all....very happy with it, no unusual tire wear either..good luck hope you get it figured out.
Tibo from Santa Barbara
Tibonious is offline
post #5 of 7 (permalink) Old 08-18-2012, 11:50 AM
CRUISERDON's Avatar
Take a very close and attentive look at the mold ring that runs around the edge of the wheel ! It is possible that the bead did not seat properly and the tire is not running true. If it is not seated the bead must be broken and wet out then resealed. This is common when dry seating a new tire. I found that an ounce of dish soap and two ounces of water make an excellant beading lube and tires will generally seat with a lower air pressure. Don't wet any more than the bead of tire and rim.
CRUISER
DON RUSSELL
Aspire Machining
'97 VN1500 91 Cubes Of Custom CLASSIC
original owner
Vance & Hine 2to1
engine, forks, ignition & carb mod's
WebCam cam & rockers hard weld & grind
NEW TOP END, NO LOOKS ALL GO GO
Maxx intake manifold system & super G carb 44mm
CRUISERDON is offline
post #6 of 7 (permalink) Old 08-20-2012, 10:01 PM
Bubba in TX's Avatar
I have been using NAPA silicon spray the past few years to set the bead on my car/scoot tires. Seems to work no problem..... does not make a mess....
Bubba in TX
2011 Voyager "Betty Clunker"
Some people collect T-shirts
I actually ride
Voyager 1700 owners...
WRAP your pipes....
You will be glad you did...
U.S.A.F. Retired
Nye County Nevada
Motor Officer Retired
Blue Knights Texas 43
Bubba in TX is offline
post #7 of 7 (permalink) Old 04-05-2013, 08:35 PM
Tibo, did you do anything with the front suspension?
William C is offline
21" Custom Wheel Kit for the Vaquero ! Roadie Vulcan 1700 14 05-02-2017 09:32 AM
swap 21" vn800a front with 16" classic wheel fosland1 Wheels and Tires 6 02-26-2016 11:58 PM
Vaquero 21" wheel AzCruizer Vulcan 1700 25 04-07-2013 10:09 PM
21" Wheel on Vaquero Roaring Toyz Wheels and Tires 1 02-20-2011 08:04 PM
