2009 kawasaki vulcan 1700 classic - Kawasaki Vulcan Forum : Vulcan Forums
 2Likes
  • 1 Post By JD Hog
  • 1 Post By 900bubba
post #1 of 3 (permalink) Old 02-24-2018, 11:38 AM Thread Starter
Question 2009 kawasaki vulcan 1700 classic
4 months ago I installed vance and hines big shots (stock air filter). rode it for month or 2 with no problems (little popping while decelerating). then I installed a power commander V with the software for my bike (vance and hines big shots with stock air) everything was good except the bike was poppy a little on deceleration. Here is where the problem started. I got on you-tube and was told to change the software setting by adding fuel to rpm"s 1500 and greater at CLOSED throttle from the number 0 to 15. You-tube said I could increase this number as far as 40. this should decrease the popping by adding fuel. Took bike out and instantly the bike stumbled or misses in the lower gears when accelerating but once the rpm's were up it would run fine. Went home and removed what I had done by decreasing the number back to 0 from 15. Took the bike out and it continued to miss or stumble. Checked software to be sure but it is back to the way it was before the problem started but the problem is still there. I'm lost, have I hurt the bike? any suggestions?
mark482 is offline
post #2 of 3 (permalink) Old 02-24-2018, 02:55 PM
JD Hog's Avatar
Year/Make/Model: 2015 Vulcan Voyager
Color: Metallic Carbon Gray/Metallic Spark Black
I would Ivanize the bike and be done with that.
Ivan's Performance Products
Peg likes this.
Jim Diebolt
2015 Vulcan 1700 Voyager ABS
"The Black Kaw"
JD Hog is offline
post #3 of 3 (permalink) Old 02-24-2018, 05:02 PM
900bubba's Avatar
Year/Make/Model: 2009 Classic LT, 2014 Voyager
Displacement/CC's: 900, 1700
Color: White/bronze
Ivanize is the only way to go.
Peg likes this.
900bubba is offline
2009 kawasaki vulcan 1700 classic mark482 Engine Work 7 09-08-2017 04:00 PM
2009 kawasaki vulcan 1700 classic mark482 New Member Introductions 1 09-03-2017 07:19 AM
Need Help 2009 kawasaki 1700 Classic cruiser99 Vulcan 1700 8 06-20-2011 03:23 PM
2009 Vulcan 900 classic LT or 2010 Vulcan 1700 Classic LT? BA Hatchet New Riders 30 02-24-2011 02:35 PM
2009 Vulcan 2000 or 2009 Nomad 1700? Which to buy? Thom Vulcan 2000 7 06-18-2010 10:19 PM
