Front Brake feels spongy Hard K/act OK? - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 6 (permalink) Old 07-16-2012, 09:07 PM Thread Starter
Dozrtravlin's Avatar
I've had my voyager abs a couple of years now but recently I have only noticed the front brake feels a little soft, the lever travelling about 3/4 of the way in. However if I put my back brake on for a few seconds first and the K/act activates the front brake is hard and the lever locks about a 1/4 of the way in. IF I pump the front brake it really doesn't make any difference to its final position or feel, still about 3/4. There are no obvious fluid leaks
The Pads are a bit more then half worn and the ABS brakes work as designed if I lock them up. 26000 km about 16000 miles.
As I said I have only just noticed this (probably there all the time) and wonder if it has always been like this but now I know about it, I am always aware of it.
Is this normal?
Do I just need new pads? or,
Is it a sign of something not quite right with the K/act braking system
Your thought please
2009 Voyager, "Battle Star"
SageBrush Bib,
LED's around Headlight,
Chrome cup holders,
Marvellas passenger and rider highway pegs,
Grasshoper backrest,
Kawasaki Gel seats,
Grey Sheepskin Seat covers,
Kawasaki Rear Speakers,
Ipod Kit,
H.D. trunk rack,
Chrome passenger board covers,
Chrome Engine plate,
Door Controller,
Fog Lights wired to High Beam on/off.
Speedo Healer, Backoff Brake Module
KAM's heat kit
BLue Knights BKAUS11 and
BlueLiners Australia
Ride with Pride
Dozrtravlin is offline
post #2 of 6 (permalink) Old 07-16-2012, 09:22 PM
davidsheek's Avatar
As I said I have only just noticed this (probably there all the time) and wonder if it has always been like this but now I know about it, I am always aware of it. Is this normal?
Your thought please
I'm having something very similar to that. No it wasn't that way when the bike was newer. In my case the rear brake lever is spongy unless I apply front brake first, then it seems to pump up the rear brake. My bike is three years old now and started this probably 4 to 6 months ago. Now I did flush out by brake fluid system about three months ago and seemed good right after that. But slowly it came back being soft again unless I apply the front brake first. I am very sure that there is no air in the brake lines. So I'm just living with it the way it is. I mean it breaks really good especially since I added the HH pads but the brake action just isn't what it used to be.
davidsheek is offline
post #3 of 6 (permalink) Old 07-17-2012, 12:14 AM Thread Starter
Thanks David glad to know I'm not going mad... As you said it still works well but i like to understand what it is. Mine is an 09 model as well and I had the brakes and clutch fluid changed a while back. My pads are still stock pads.
I just went out and tried my back brake and it does the same as yours, hold the front brake for a couple of seconds and the back brake pumps up hard. Must be the K/act system
I wonder if it has something to do with the amount of meat left on the pads.
Thats 2 so far and both 09's so odds on there ahould be a few more with the same issue
SageBrush Bib,
Chrome cup holders,
Kawasaki Gel seats,
Ipod Kit,
H.D. trunk rack,
Door Controller,
KAM's heat kit
Ride with Pride
Last edited by Dozrtravlin; 07-17-2012 at 12:44 AM. Reason: Took bike for a test ride to confirm issue was front and rear
post #4 of 6 (permalink) Old 07-17-2012, 01:09 AM
davidsheek's Avatar
It shouldn't have anything to do with the amount of pad that's left as they are self adjusting. I don't know why they are doing that. Just hope it doesn't get any worse, if you know what I mean.
post #5 of 6 (permalink) Old 07-17-2012, 07:17 AM
rick's Avatar
Different bike, but I've noticed on my 05 800 that my front brake seems much stronger at the lever right after I remove the front wheel for tire change, after the caliper is spread for removal and then pumped couple times to readjust the brake. After day or to of riding lever seems soft again. No ABS or linked to rear in any way, rear is drum and cable operated on mine. I just live with it, always stops me.
rick is offline
post #6 of 6 (permalink) Old 07-17-2012, 10:04 AM
Telly's Avatar
I have an '11 and the brakes act the same way; apply the rear brake, not much there, apply the front with it, and it pumps up.
Telly
2011 Voyager 1700 ABS
Patriot Guard Rider
iPod Adapter
OEM Comms
Kury ISO Grips
Kewl Metal Helmet Locks
Racn' Ray's Throttle Mod
Kury Longhorn Offset Dually Highway Pegs
Cobra Luggage Rack
Cobra Saddlebag Lid Guards
Stebel Compact Nautilus Horn
Clearview Tinted 17" Shield
Sagebrush Designs Tank Bib
Marvellas Passenger Pegs
Telly is offline
Front wheel feels squirrely at low speed murpheeee Vulcan 900 5 04-05-2017 01:38 PM
Front end feels a little vague mrwiz326 Oil and Lubrication 2 10-25-2015 05:56 PM
Front end feels loose OldDave Vulcan 900 16 06-11-2014 12:50 AM
Ok OK OK...fan switch wiring info RACNRAY Vulcan 1700 48 09-25-2013 03:01 AM
Voyager K-act or non K-act captwjf Vulcan 1700 20 05-03-2010 02:07 PM
