DynoJet PCV - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 5 (permalink) Old 07-13-2012, 06:46 PM Thread Starter
DynoJet PCV
Just installed a Power Commander V on my 2011 Vulcan Nomad per instructions included in the box but I have no power to the unit. Any ideas??
visa11 is offline
post #2 of 5 (permalink) Old 07-13-2012, 08:10 PM
davidsheek's Avatar
Yes connect your laptop to it via USB cable. With the loaptop on it will power up the PCV. If it doesn't then there must be something wrong with it. Then call the power commander guys.
You sure you connected all the wires correctly?
Also did you get PCV # 17-003 ?
davidsheek is offline
post #3 of 5 (permalink) Old 07-13-2012, 09:17 PM
Combat72's Avatar
Don't mean to high jack your thread but I'm having PCV/Autotune issues as well. Installed my PCV (17-033) and Autotune tonight. It doesn't appear the Autotune is working. I did enable it in the software and tapped into the Blue wire beside the battery as a switched power source. How can you tell the Autotune is working? In the bottom right hand corner of the software there is an icon "Autotune Running" and it is not doing anything. Help.
Frank
2010 Voyager/ Metallic Diablo Black/Metallic Imperial Red
1972 Norton Commando - Yellow
PCV(Fuel & Ignition) With Autotune
Gear Advance Fuel & Ignition Mapping
Cobra 4' Scalloped Tip Slip-Ons
Wrapped Exhaust Manifold
Kuryakyn ISO Grips with RacnRay Mod
Kuryakyn Bar End weights
Ultimate Mid-Rider
Polk Audio DB521 speakers
K&N Air Filter
Rear Speakers
Mirror Risers
iPod Adapter
Combat72 is offline
post #4 of 5 (permalink) Old 07-13-2012, 11:20 PM
davidsheek's Avatar
Sorry I don't have a Autotune. Looks like you need to call tech support at PC.
post #5 of 5 (permalink) Old 07-14-2012, 05:11 AM
17-033 is the unit with fuel and ignition
17-006 is the unit for fuel only
I didn't want you to be confused thinking you may have perhaps purchased the wrong PCV unit. Both of the above models work with the Nomad.
That said, as a previous poster indicated, hook up your laptop to the PCV and see if it powers up. If everything is O.K. in that regard, you can actually start the bike with your laptop connected and see that the PCV is reading RPMs and Throttle position. That will allow you to see that the wire taps you installed are picking up those pulses correctly. If that is working and the bike is running, you're probably fine. If in doubt, contact tech support.
Dave
dpbaker is offline
Fi2000R or Dynojet Power Commander??? NCVN1600 Engine Work 16 04-02-2010 02:14 AM
Dynojet Maps schon731 Vulcan 900 13 08-15-2009 12:50 PM
