Moved Air Sensor - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 35 (permalink) Old 07-13-2012, 03:53 PM Thread Starter
Moved Air Sensor
Moved the air sensor to the front of the bike, mounted it to the hole in the front.It does work.The bike seems to run smoother.Also wrapped the pipes and did the throttle mod.All of the mods helped. made a definate improvement.Going to cut the seat pan out.Did this on my previous bike a Valkrie , it gives a little more cush to the butt ,no hard pan stopping the foam from settling.
gibi is offline
post #2 of 35 (permalink) Old 07-13-2012, 04:00 PM
RACNRAY's Avatar
That's good news, the better our skoots run and feel the better, uh, we run and feel!! Neat how that works out!!
RACNRAY
RACNRAY is offline
post #3 of 35 (permalink) Old 07-13-2012, 08:20 PM
rusty360's Avatar
What hole? Do you have a picture?
2014 Honda Gold Wing
2011 Vaquero sold
2009 900lt sold
rusty360 is offline
post #4 of 35 (permalink) Old 07-14-2012, 07:25 AM Thread Starter
air sensor
Sent you e mail Theres a hole on the right side of the frame,at the goose neck just in front of the tank below the bars check I think youll find it.U can check jp 58 he put a picture of it Hope this helps.I have a1700 classic but I think the hole is there o all the 1700??
gibi is offline
post #5 of 35 (permalink) Old 07-14-2012, 08:16 AM
6MM bolt hole in goose neck
Here's a pic of the mounting area. There's a 6mm threaded hole there.
Name:	temp senser.jpg
ID:	12161   Click image for larger version
Name:	temp sensor.jpg
jp58 is offline
post #6 of 35 (permalink) Old 07-14-2012, 02:51 PM
rusty360's Avatar
Thanks JP, one more question, did you make that bracket or did you buy it somewhere and drilled it out to make it work? What did you plug up the hole left in the housing with?
2011 Vaquero sold
2009 900lt sold
rusty360 is offline
post #7 of 35 (permalink) Old 07-14-2012, 05:07 PM
new kawi rider's Avatar
purpose
What is the purpose of moving the air sensor?
2010 Voyager
Scootworks 2 inch fat risers
vance&Hines slipons
Mustang Wide Touring studded
PCV
Michelin commander 2
Ipod adapter
Titanium header wrap
8 to 12.5 inch bagger windshield
Iso grips with Rays throttle mod
Chrome rear floor board covers
Kams Kit
new kawi rider is offline
post #8 of 35 (permalink) Old 07-14-2012, 06:01 PM
BOTM Winner, August/2012
Dewey405's Avatar
I imagine the bike adjusts for the quality and amount of air coming in so if it is cold, fresh air right at the front the bike thinks it needs to add fuel to compensate therefore running better.
2012 Nomad 1700
VBA #02021
VROC #34848
Dewey405 is offline
post #9 of 35 (permalink) Old 07-14-2012, 06:40 PM
power commander
So if you have a power commander its a mute point?
2010 Voyager
vance&Hines slipons
PCV
Ipod adapter
Kams Kit
post #10 of 35 (permalink) Old 07-14-2012, 09:51 PM
I just bought a L shaped bracket from a hardware store and drilled the holes i needed. I got a plastic snapin plug from the hardware store also. I think it was 1/8 inch in size
jp58 is offline
Just moved up... ol' school Vulcan 1700 3 09-13-2013 07:08 AM
cross country tips (moved from new member intro forum) elmarko General Vulcan Talk 10 08-06-2013 05:01 PM
Moved up to a 1700 Classic Blockhead Vulcan 1700 5 02-11-2013 09:09 AM
Bike had to be moved MN-Rider General Vulcan Talk 11 03-19-2011 07:08 PM
Moved up - many thanks RodM Vulcan 900 3 12-07-2009 09:05 PM
