Psi for rear shock - Kawasaki Vulcan Forum : Vulcan Forums
post #1 of 5 (permalink) Old 07-13-2012, 12:44 PM Thread Starter
Psi for rear shock
I am getting ready for a long (6000 mi) trip and will be pulling a pop up camper. It tips the scales at about 500 lbs. I come in at 205 lbs and will have about 50 lbs of gear on the backseat. Does anyone have a good idea of the amount of air I should use in my rear shocks?. How about tire pressure?
gdknepp is offline
post #2 of 5 (permalink) Old 07-13-2012, 01:03 PM
sansfaute's Avatar
Send a message via Yahoo to sansfaute
Look in the owners manual specs should be there Shock hash marks 111 for heavy load
The max setting for the shock is 43 psi. Use a quality hand pump with a gauge. Make sure both sides are equal. I run 40 psi in the rear tire, 28 in the front you could go up to 36 in the front play with it and see what gives you the best ride.
Have a Safe trip
Live Long and Ride
2009 Voyager,
Passenger Floorboard underside Chrome covers
Top bag rails
Lower bag rails
Chrome engine plate
Speed healer
Strebel Air horn
VN1500 side stand
RacnRay's throttle mod
I pod connector
Rear speaker kit
V Star Trunk rack
Bag Liners
Kuryakan off set foot pegs
K&N air filter
HD/Dunlop Wide whites
Kawasaki Zumo Gps mount
Zumo550 Gps
Cobra fuel processor
Cobra billet tip slip ons
Countless
VROC 31578
sansfaute is offline
post #3 of 5 (permalink) Old 07-13-2012, 01:14 PM
This chart may give you an idea of where to start with your shock pressure.
Name:	rear shock pressure.JPG
11NOMAD is offline
post #4 of 5 (permalink) Old 07-13-2012, 02:41 PM
Bubba in TX's Avatar
42 psi for me and mark III
Bubba in TX
2011 Voyager "Betty Clunker"
Some people collect T-shirts
I actually ride
Voyager 1700 owners...
WRAP your pipes....
You will be glad you did...
U.S.A.F. Retired
Nye County Nevada
Motor Officer Retired
Blue Knights Texas 43
Bubba in TX is offline
post #5 of 5 (permalink) Old 07-16-2012, 04:45 PM
What is the tounge weight of the trailer?
I don't disagree with what the other have already resonded, but to know the load on the bike you would need to add the tougue weight to your weight and the other luggage. You would also want to know that so you don't exceed the recomended load on your hitch.
That said, I ran 33 psi in the rear shocks this weekend with a 500 pound load on the bike (two up). The bike was very well mannered at that weight. I was hoping this bike was up to the the task and it appears it is.
Best of luck.
2012 Vulcan Voyager ABS
stoutman is offline
Is 0.5 psi loss on rear tire in 48 hrs ok? btom Vulcan 800 7 08-17-2016 08:17 AM
nomad rear shocks psi number mes882 Vulcan 1700 10 09-07-2014 02:45 PM
shock psi hillclimber General Vulcan Talk 6 08-20-2014 05:57 PM
rear 900 shock and 800 shock tindog Vulcan 900 4 04-02-2012 10:22 PM
Are you really running the correct PSI's ItsMePaul Vulcan 2000 12 04-23-2011 08:05 AM
